Chirping noise while driving - Mustang Evolution
Old 05-11-2015, 06:04 PM   #1
For I while I've had an annoying chirping noise that sounds like a bird or something. It is speed related like the faster I go the faster the noise. Most noticeable with windows down coming from right side, goin anywhere from 15-50 mph. It's more consistent when turning left or even just putting a little more weight on right side by swerving a little. When driving straight it's hit and miss but I think bumps in the road make it chirp too. When breaking almost all noise disappears. Break pedal does not vibrate so I doubt it's the rotors I've had all 4 wheels off 3 times greased everything with no luck. Any ideas?
Sent from my iPod touch using Mustang Evolution
Calebnc302 is offline   Reply With Quote
Old 05-11-2015, 06:41 PM   #2
Sounds like the front right wheel bearing.
Old 05-11-2015, 06:42 PM   #3
Check the wheel bearings for any play.
Old 05-11-2015, 06:44 PM   #4
Or if its a higher milage vehicle, just replace both sides and do the brakes too if they weren't done recently. Front wheel bearings are cake, you just need a big goddamn breaker bar and a 36mm hardened deepwell socket. You can get them at any parts store.
Old 05-11-2015, 07:02 PM   #5
Ok thanks for the replies. Wheel bearings did cross my mind so will replace them in near future.
Old 05-11-2015, 07:11 PM   #6
They're a wear item just like everything else. OEM is usually good for 100k. Parts store replacements... I've had good luck with in past vehicles and my Expy as well. 50k so far on a generic rockauto front left wheel bearing and its dead silent. Just did the back left 5k ago with another generic and its fine. Have 2 more in boxes for the right side waiting to go on.
Old 05-11-2015, 08:46 PM   #7
Thanks for the info man. My 03 has 177k on her. They might be original lol who knows
Loud chirping noise PBrown92 1996-2004 Mustang GT 4 11-22-2013 05:20 PM
chirping noise at idle on clutch,could be throw out bearing? fctwf 1996-2004 Mustang GT 53 06-05-2013 12:33 AM
Noise from engine while driving 813floridaracin Pre-2005 V6 Mustang 2 11-25-2012 07:58 PM
Metal squealing noise after driving for a while Patches89 1979-1995 Mustang GT 11 08-20-2012 06:09 PM
12' Convertible makes chirping noise over bumps by conv latch?? Yellow50 2011-2014 Mustang GT 2 04-04-2012 12:15 PM
04:12 PM
