Bama tune - Mustang Evolution
Old 05-11-2015, 11:33 PM   #1
CandymanGT's Avatar
Bama tune
Holy Jebus, I just installed my 87 octane Bama tune and wow what a freaking difference. MUCH more responsive, and talk about a seat of the pants difference. I don't know how much power I actually picked up on the 87 tune but its a night and day difference in feeling. Anyway that's it, just wanted to put it out there.
Anyone know how much HP you pick up on a 2002 with Bama 87 performance tune with a CAI? I've looked around a bit but no one talks about the 87 tune. I plan to drive until the low fuel light and refill with 91 and put that tune on it then but for the interim I was curious.
Mustang 3: Return of the Happy
CandymanGT is offline   Reply With Quote
Old 05-13-2015, 09:05 PM   #2
Its going to be more throttle response than overall power. And it all depends on what other bolt ons you've done. CAI does next to nothing, the added performance is 99% from the tune.
Glad you are happy with it, but I would also HIGHLY recommend you get a wideband AF gauge. Canned tunes tend to run rich and you have no way of knowing if your AF is good or too lean/rich unless you've got a wideband. They're only $140 on Amazon these days and $20 for your exhaust shop to weld in the bung.
Old 05-14-2015, 12:50 AM   #3
CandymanGT's Avatar
Most definitely, I might well make that my next mod.
Old 05-14-2015, 04:58 AM   #4
GHJA614's Avatar
Glad you felt you 87 tune cause mine was **** lol. My 93 Race tune is where its at
2003 Black GT - SLP LM1, O/R Xpipe, SR CAI, Bama Tuned, MGW Short throw shifter
GHJA614 is offline   Reply With Quote
Old 05-14-2015, 08:20 AM   #5
CandymanGT's Avatar
I'm looking forward to the 91 oct (California) tune. Been not filling my tank to drop the fuel to the low fuel light so I can refill with 91 'cause I don't trust octane boosters. I think the main change from the 87 tune is in behavior and throttle response. The 91 should actually add some power.
Old 05-16-2015, 04:25 PM   #6
elvergas.4611's Avatar
I put octane booster once and it completely messed up the tune, I have a 93 tune and it was super boggy 👎👎.i don't recommend it at all!!
elvergas.4611 is offline   Reply With Quote
Old 05-16-2015, 04:38 PM   #7
Octane booster is more snake oil. If you want high octane then go buy race gas. Or E85.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 05-16-2015, 05:24 PM   #8
Rapinator126's Avatar
Torco works
Rapinator126 is online now   Reply With Quote
Old 05-16-2015, 05:43 PM   #9
Torco does, tuners I've talked to say they worry about getting the ratio and a good mixture in the tank right tho...
I really wish I had an E85 station close by...
Old 05-16-2015, 05:46 PM   #10
You are correct scotty. I used it for awhile b4 I went to e85. It's a pain and gets $$ every time you fill up though.
Old 05-16-2015, 06:03 PM   #11
Yeah I imagine that would suck to have to worry about a mix every time you fill up. I have no idea why NJ doesn't have more E85... maybe because we have a bunch of refineries and are sandwiched between 5 real big ports so gas is stupid cheap without having to worry about it?
I mean there are always 2 drag strips relatively close buy to buy 110 from I guess. Or Methanol for mixing up my own RC airplane fuel lol.
Old 05-16-2015, 06:23 PM   #12
Do you need to retrofit anything to run E85 or just get a tune and start pumping?
Its a legit question btw
Old 05-16-2015, 06:24 PM   #13
I wouldn't say it's snake oil. But I personally wouldn't waste my time or money on it
I want to say that only the nos brand octane booster shows you a point system to knowing what octane you're at.
Cheaper brands don't say anything and therefore are pointless to use.
It's a lot of money just to boost your octane a couple of points for one tank lol
Judge_dredd is offline   Reply With Quote
Old 05-16-2015, 07:54 PM   #14
What year car do you have?
Old 05-16-2015, 07:58 PM   #15
Its an 03 V6. I'm not going to bs and say i MAY do it cause I'm too broke to get a tuner but there is a gas station by my moms house that just put an E85 pump bit only see newer import cars use it. I wanted to pump some for ****s and giggles
Old 05-16-2015, 08:00 PM   #16
03 V6? Just drive it and be happy its not making you car poor lol.
Old 05-16-2015, 08:02 PM   #17
Oh I'm satisfied but i just wanted to know if any hoses or pipes needed to be changed. It was just a curiosity thing
Old 05-16-2015, 08:08 PM   #18
You will need injectors and a tune at the least for your car.
May possibly need more for your car not a 100%
But injectors and a tune are for sure.
Old 06-01-2015, 04:23 PM   #19
Ryan2011's Avatar
Why would you use 85 octane gas? Is there a benefit?
Ryan2011 is offline   Reply With Quote
Old 06-01-2015, 04:33 PM   #20
Not sure if serious or troll...
Old 06-01-2015, 04:42 PM   #21
Ryan2011's Avatar
Lol no I'm serious, I've always used 87 octane and have always been curious to what the 85 was used in and what for
---------- Post added at 05:42 PM ---------- Previous post was at 05:41 PM ----------
I mean it's cheaper so I assumed it was a lower grade??
Old 06-01-2015, 04:45 PM   #22
WJL
Rapinator, you going to explain this one, its not 85 Octane in fact it is much higher like 96 or 98 Octane maybe even higher depending on what formual you use to calculate the octane rating, its an ethanol based fuel
WJL is offline   Reply With Quote
Old 06-01-2015, 04:46 PM   #23
Ryan2011's Avatar
But ethanol isn't good for the motor right?
Old 06-01-2015, 04:53 PM   #24
alecas447's Avatar
85% ethanol.
If you're going to run it, good idea to get an aftermarket fuel pump
alecas447 is offline   Reply With Quote
Old 06-01-2015, 05:05 PM   #25
Ryan2011's Avatar
Ohhh that makes more sense now!!
Old 06-01-2015, 05:08 PM   #26
e85 is ethanol not 85 octane gas. Try 110 octane
Old 06-01-2015, 05:09 PM   #27
Ryan2011's Avatar
🙈 geese lol I had ethanol and octane mixed up!!
Bama hybrid tune vs race tune tq hp curve rick9550 2011-2014 Mustang GT 7 07-14-2013 06:54 PM
Bama tune with aed cam tune? Mustang32Bill 2011-2014 Mustang GT 23 05-25-2013 06:13 AM
bama race tune > bama hybrid tune 13 stang22 2011-2014 V6 Mustang 11 04-16-2013 05:26 PM
Bama tune or lund tune or steeda tune Mustang32Bill 2011-2014 Mustang GT 89 11-12-2012 10:45 AM
Question on installing Bama tune if previous tune already loaded on car ljn21 2011-2014 Mustang GT 7 08-01-2012 10:08 AM
12:08 AM
