Set Idle Screw / Idle problem - Mustang Evolution
Old 05-12-2015, 07:08 AM   #1
v8pony's Avatar
Last week I was having an idle issue, before eventually replacing the IAC my buddy was messing with the idle screw on the TB..well long story short after replacing the IAC I had to try my best to get that idle screw back to the exact same stock position, I did the best I could, car idles around 800 rpm. Now the problem I'm having is the idle is like consistently 800 rpm, whether its cold or warm, the car always idles at 800, my car has ALWAYS idled around 1000-1100 when cold and drops down in the matter of minutes, its just a bit odd too me..by messing with that idle screw did I somehow bypass the PCM from controlling my idle? Is there a reset idle procedure i should have went through after all of this? Thanks guys
2002 5spd GT
Feb 2013 Mustang of the Month
Old 05-12-2015, 07:35 AM   #2
fenixignition's Avatar
PaladinMicro
you will probably need to pull the negative off the battery for 10 minutes, then start the car again, and let it idle until warm and go for a drive.
2002 GT 5sp. 16x,xxx miles
Old 05-12-2015, 11:41 AM   #3
v8pony's Avatar
Is there a proper way to make sure that idle screw is set in the correct position? Or will the PCM adjust the idle accordingly after the idle re learn procedure?
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
2002 5spd GT
Old 05-12-2015, 11:42 AM   #4
v8pony's Avatar
Hmmm where's Scotty lol
2002 5spd GT
Old 05-12-2015, 02:57 PM   #5
v8pony's Avatar
A buddy told me to try this. Unplug IAC, start motor, adjust idle screw so motor barely runs 400-500 rpm, turn motor off, plug back in IAC, start motor. Anybody hear of this procedure?
2002 5spd GT
Old 05-12-2015, 09:54 PM   #6
Yes!
Fenix provided a link to PaladinMicro in his post that leads you to the VERY BEST 96-04 Mustang information that can be found on the internet. Period.
There are detailed instructions on how to properly adjust a Throttle Body on that website. As well as a TON of other useful information!
Old 05-13-2015, 05:27 AM   #7
v8pony's Avatar
Originally Posted by straybullitt View Post
Yes!
I adjusted the TB last night and went through the idle re learn process, idles great now....funny I've been on cliffys site dozens of times and I completely forgot he had the TB adjustment in full detail on there lol..thanks guys!
2002 5spd GT
Old 05-14-2015, 07:50 AM   #8
Hey, sorry to just abandon you. but glad you got it worked out. Between work, then being out of town, and juggling a puppy in the middle of it all, I havent been on here as much as i usually like.
As far as the idle screw goes, I noticed that when mine is too low and closed too much, when i press the pedal, i feel like im scraping the valve off of the surface everytime i hit the gas, meaning that i try to lightly tap the gas, but it requires a bit of pressure to break free, and when it does, i end up revving too high. With the idle screw pushing a tad on it, it fixed that issue, and the computer relearns what is "Normal", and calibrates itself accordingly with the gas flow. as for your tps sensor ( i know you didnt ask, but figured i would throw this in there) it re zeroes every time you start the car, so there is no adjustment required on those.
Old 05-15-2015, 10:07 PM   #9
Panther140's Avatar
Ahh the joys of EFI.
I set my idle the other day. Took me 2 seconds with no tools, no BS involved. Love carbs
Panther140 is offline   Reply With Quote
roots or screw supercharger bigpomps Pre-2005 V6 Mustang 20 04-27-2005 06:20 AM
Headlamp adjuster screw 95_six_banger Mustang Parts for Sale and Wanted 2 08-20-2004 09:49 PM
How many threads to screw in a bulb njstang97 Mustang Audio & Video 4 05-01-2004 06:26 PM
screw midwest mustang. Smokedya95stang The Bar 21 04-24-2004 09:12 PM
05:46 AM
