Speedometer not working - Mustang Evolution
Old 05-12-2015, 01:52 PM   #1
Question Speedometer not working
Hi all,
A couple months ago I picked up a '96 GT for a project car. I have it nearly drivable, except the speedometer isn't working. A, what looks to be, new speed sensor came with the car and a second dash came with the car. So far nothing has worked. I had the new speed sensor put in, but no love. The old speed sensor is still showing a resistance with my multimeter, so I am assuming that isn't the problem. I have taken apart the first dash and it was looking fine except for a few burnt out bulbs.
The check engine light is on, the low oil level light is on, and the air bag warning light is flashing. Hopefully tonight I can get an OBDII reader on the GT, but without the code(s) the speedo problem is looking to be either the wiring harness or the ECU.
Assuming the dash and speedo sensor are good is there anything else to check besides the ECU and wiring harness?
Also, if it is the ECU are there any programmable/more modern ECUs for the fourth gen mustangs?
decapodascampi is offline   Reply With Quote
speedometer stopped working takashicago 2005-2010 Mustang GT 9 05-18-2014 08:34 PM
Speedometer not reading DutchManDann 1996-2004 Mustang GT 12 12-21-2013 09:25 PM
Speedometer MyColor lights will not turn on. Tyrannax General Mustang Discussion 4 09-15-2013 02:05 AM
A\C working then not working Bohogin Pre-2005 V6 Mustang 3 07-14-2011 02:44 PM
speedometer and gas gauge not working?? rob913 1979-1995 Mustang GT 0 07-03-2010 09:00 AM
06:07 AM
