Performance or Appearance? - Mustang Evolution
Old 05-13-2015, 07:26 PM   #1
Bellairs's Avatar
Probably the biggest question that circles around my head when thinking about what I want for my Mustang. What should I go more of?
Performance I feel would cost more money and would take more time. I'd like to put in headers(contemplating long or short still) and a tune since I have and exhaust, Throttle body and an cold air intake. I was told board out heads too but that alone I found out is a solid 1,500$ upgrade.
Appearance I think would cost way less and would take less time. I was thinking painting some of my interior black and getting some carbon fiber. As well as LED's, black 18" Saleens, sequential taillights, possible engine painting, colored gauges and maybe some side scopes. I'm kinda going for a Silver/Black look.
I have a minimum wage part time job, so I don't make a lot of money every week (probably around 175$). With that I'm planning on upgrading in a few years to a 2007-2013 GT so I don't want to throw a lot of money into the car.
Basically, what is everyones opinions on the best performance and appearance mods and in my case, what is the better path to take?
Name:	ImageUploadedByMustang Evolution1431566687.651203.jpg
ID:	182523Click image for larger version
Name:	ImageUploadedByMustang Evolution1431566729.318341.jpg
ID:	182525Click image for larger version
Name:	ImageUploadedByMustang Evolution1431566757.002188.jpg
01 GT
Bellairs is offline   Reply With Quote
Old 05-13-2015, 07:43 PM   #2
Black8thElement's Avatar
Everyone is different honestly i chose appearance first. She looks and sounds the part for sure. Now I'm focusing on backing up its bark if that made any help.in your decision.
Some guys do performance mods first making it look like a sleeper and then proceed to damage someone's self confidence Yaknow
Black 2008 Decepticon GT "If it ain't hooking, it ain't booking" edition
Black8thElement is offline   Reply With Quote
Old 05-13-2015, 07:46 PM   #3
GHJA614's Avatar
you basically answered your own question.. If you are going to get an s197 soon just do appearance mods . Is this your DD? Also if you do plan on doing performance mods don't waste your money on shorty headers.
2003 Black GT - SLP LM1, O/R Xpipe, SR CAI, Bama Tuned, MGW Short throw shifter
GHJA614 is offline   Reply With Quote
Old 05-13-2015, 07:56 PM   #4
CandymanGT's Avatar
With that level of income it going to be very hard to do anything. I'd suggest investing in Amsoil fluids (oil, transmission fluid, gear fluid) to try and make it last as long as you can so it will be around for upgrades in the future. Those fluids also last a lot longer than others so while more expensive at first you end up needing to change them less often and saving money. I'd also concentrate your efforts on the rear suspension because its notoriously bad.
Deciding between performance and appearance is really going to be a personal choice. You need to decide which is going to more enrich your experience with your car and no one here is really going to be able to answer that for you. I'll tell you this though, you've done the cheap stuff. The only other other cheap thing performance wise would be J-mod if you have an auto trans. A tune is a kinda cheap mod that does do a lot to how the car will behave.
Mustang 3: Return of the Happy
CandymanGT is offline   Reply With Quote
Old 05-13-2015, 08:08 PM   #5
phatspeed7x's Avatar
I personally did a blend of both to mine. Got the car to look how I wanted it. And added a few items that would help it go a little quicker. It's not fast by any means, but I look good, and have fun while driving it.
~2004 GT with Bolt ons~
phatspeed7x is offline   Reply With Quote
Old 05-13-2015, 08:27 PM   #6
Steve96's Avatar
Lower it with lowering springs, get a staggered set of wheels, Mach 1 grill delete. The new edge mustang's can look really good with these mods. Get the SR lowering springs, under $200 I think, staggered wheels and tires, even looked for a used set on Craigslist.
---------- Post added at 09:27 PM ---------- Previous post was at 09:26 PM ----------
And a Mach 1 chin spoiler as well. Another cheaper appearance mod
1996 GT
Old 05-13-2015, 09:02 PM   #7
GHJA614's Avatar
also new shocks and struts and CC plates for those springs ^^^
Old 05-13-2015, 09:08 PM   #8
$175 a week? Fresh fluids/maintenance and drive it/enjoy it and save your money. Not going to do much of anything on that budget. Maybe $50 here and there for a few little things... I guess appearance... but doing carbon fiber overlays and glow gauges and LEDs is kinda ricey...
As far as interior paint. You will need to pull the panel/part in question, COMPLETELY strip it with soapy water, then mineral spirits, then soap and water again, let it air dry, hit it with SEM interior prep and then adhesion promoter and FINALLY the correct SEM interior dye for your desired color and then multiple coats of clear on top of that. Might be easier to just go to a junkyard and pull the part you need in the color you want although if you are patient and do it right a dye job will be as good as OEM. I'd personally just clean your interior real well with good cleaners/conditioners (NOT ARMOR ALL) and make it real nice as is. But that's just me.
Old 05-13-2015, 09:16 PM   #9
keeney35's Avatar
This might be the look you wantClick image for larger version
Name:	ImageUploadedByMustang Evolution1431573266.625154.jpg
ID:	182529Click image for larger version
Name:	ImageUploadedByMustang Evolution1431573279.548107.jpg
ID:	182530Click image for larger version
Name:	ImageUploadedByMustang Evolution1431573292.137159.jpg
ID:	182531Click image for larger version
Name:	ImageUploadedByMustang Evolution1431573305.145102.jpg
ID:	182532Click image for larger version
Name:	ImageUploadedByMustang Evolution1431573337.893794.jpg
ID:	182533Click image for larger version
Name:	ImageUploadedByMustang Evolution1431573357.688324.jpg
I love the black/silver look, so there's some ideas for ya
keeney35 is offline   Reply With Quote
Old 05-13-2015, 09:20 PM   #10
Depends on if he has any bills or not. I made less than that in high school and was able to do some mods. But I was already keen with my money and investing.
Old 05-13-2015, 09:23 PM   #11
GHJA614's Avatar
I would try and find a better job for the summer assuming you're in high school or college. Work full time = more mods
Old 05-13-2015, 09:25 PM   #12
Originally Posted by keeney35 View Post
This might be the look you wantAttachment 182529Attachment 182530Attachment 182531Attachment 182532Attachment 182533Attachment 182534
Vinyl roof looks pretty good on that. If the paintscratch kit does not turn out how I want it to for some reason on my car I'll be going that route. AM kit?
Likely just a cell phone if even that... Maybe insurance? I dunno with that budget I'd just pocket the money for going out and doing stuff although being under 21 kind of limits what you can do.
Old 05-13-2015, 09:27 PM   #13
GHJA614's Avatar
not if you're 6'2 Tim Scott from Minnesota
Old 05-13-2015, 09:27 PM   #14
Do exhaust then save up for the car you want.
Adventure till you drop
Old 05-13-2015, 09:31 PM   #15
I didn't have any expenses in high school thankfully. Parents paid gas and insurance..... But they saw that I was also investing my money so they figured it would be better to let me do that than have to pay bills. Luckily they still help me out with a lot of stuff since I'm investing 70% of my money currently. We both see it as more beneficial to let me invest most of my money than have various payments.
Although in high school when I was able to afford mods it was basic stuff. Tinted headlights, VHT tail lights, plasti dipped wheels, tune, and short shifter
Old 05-13-2015, 09:36 PM   #16
KATO's Avatar
Just do Exhaust and Cold Air Intake. Save up for the new car. Get it out of your Head to do any type of Head work, save money, it's not needed anyway.
Old 05-13-2015, 09:38 PM   #17
This ^^^
You can do little things, but don't spend all your money on the car. Will help a lot more in the long run.
Old 05-13-2015, 09:58 PM   #18
keeney35's Avatar
Scotty, the roof isn't a wrap it's dip but I did it with a gun so it's actually done well.. Has held great, smooth finish
Old 05-14-2015, 09:12 AM   #19
Bellairs's Avatar
I only have my insurance which is payed for a few more months so I have time.
01 GT
Old 05-14-2015, 12:09 PM   #20
I have this issue on both sides.
Happened on my Cobra too but in a different spot. Not hard to fix honestly, just time consuming.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 05-14-2015, 12:26 PM   #21
keeney35's Avatar
Mine was the same way, and some sundamge to the clear
Old 05-14-2015, 01:00 PM   #22
Yeah it's weird especially since the paint on the rest of the car is perfect. Eh oh well.
Old 05-14-2015, 01:34 PM   #23
WJL
I vote for performance
WJL is offline   Reply With Quote
Old 05-15-2015, 08:42 PM   #24
Panther140's Avatar
I would just get this instead of all that girly bling bling ****. Your car already looks good.
http://www.brothersperformance.com/u...FRCnaQod9GMACA
Panther140 is offline   Reply With Quote
Appearance VS Performance? Njd92 2011-2014 V6 Mustang 14 11-15-2013 03:53 AM
performance vs appearance stangcobra General Mustang Discussion 23 01-01-2013 05:56 PM
Cheap appearance or performance upgrades? 98GTCONV 1996-2004 Mustang GT 11 08-22-2012 09:52 AM
Appearance Feedback Needed CaptHowdy5150 Mustang Audio & Video 33 02-20-2004 07:26 AM
Welcome to the Appearance Section !!! Junior2561 Mustang Audio & Video 8 02-17-2004 10:36 PM
02:01 PM
