Rear end help! - Mustang Evolution
Old 05-16-2015, 12:49 PM   #1
dayves's Avatar
Rear end help!
As of yesterday my reared started making a really loud clunking noise when I'm taking off an it seems to mainly be when at lower RPMS (could just be a coincidence) but it's extremely loud and makes a very noticeable jerk as well when it does it. It will continue to do it as I go through the gears but less and less as I get into the higher gears. I have no knowledge of rear ends so I'm completely clueless as to what it could be. Any and every advice would be much appreciated. Thanks in advance
dayves is offline   Reply With Quote
Old 05-16-2015, 01:28 PM   #2
dayves's Avatar
It is a 5 speed
Old 05-16-2015, 03:29 PM   #3
Could be the differential going out or could be a control arm. Is it all stock or are there aftermarket parts back there?
Sent from my LG-D801 using Mustang Evolution mobile app
Old 05-16-2015, 04:47 PM   #4
dayves's Avatar
I discovered it was my gears, somehow the smaller ones got destroyed and were missing huge chunks. I'm in the process of replacing them right now.
Old 05-16-2015, 05:46 PM   #5
Good deal. Make sure you use only Ford Racing gears. I've never ever heard of that happening tho... weird.
Old 05-17-2015, 12:46 PM   #6
Panther140's Avatar
too many horsepowers obiously
Panther140 is offline   Reply With Quote
Old 05-17-2015, 01:23 PM   #7
I think that he is referring to the spider gears. It is a very common thing for them to wear out and break in four wheel drives with large tires. Not so common in cars, though.
Old 05-17-2015, 07:00 PM   #8
dayves's Avatar
That's what I've been told. Someone said it could be caused from dumping the clutch but I've never dumped the clutch once, I'm not sure what caused it.
Old 05-17-2015, 07:02 PM   #9
Panther140's Avatar
Remember kids, its very important to keep your rear end lubed up
Old 05-17-2015, 07:06 PM   #10
dayves's Avatar
Old 05-17-2015, 07:29 PM   #11
No comment... but yes... could be from a previous owner.
Old 05-17-2015, 08:13 PM   #12
dayves's Avatar
I also know the clutches on the inside (not sure the proper term) were wearing out and were basically shot when I replaced them yesterday. Not sure if that could've caused it??
v6 rear end help? ivan1229 Pre-2005 V6 Mustang 7 05-15-2012 10:32 PM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
1995 GT Rear End... Help please. justinsstang Pre-2005 V6 Mustang 6 03-25-2009 02:29 AM
Need Help with Rear End Problem on my 70 Mustang blk66stang Classic Mustangs 3 12-03-2008 02:51 PM
04:23 AM
