Why won't my Maximum Motorsports firewall adjuster fit? - Mustang Evolution
Old 05-16-2015, 07:08 PM   #1
GHO5T5NIPER's Avatar
Hey guys why won't my MM firewall adjuster screw in all the way in the firewall? It hits the body on the the side by the pedals.Click image for larger version
Name:	ImageUploadedByMustang Evolution1431824858.908617.jpg
Here's as far as it screws in before it hit that.Click image for larger version
Name:	ImageUploadedByMustang Evolution1431824886.173770.jpg
Is that as far as it goes or do I have to bend that metal piece?
GHO5T5NIPER is offline   Reply With Quote
Old 05-16-2015, 09:45 PM   #2
Figured it out. Had to file a bigger hole for the adjuster to fit down further.
Old 05-16-2015, 10:17 PM   #3
Was going to say, has to be an install error. I've never heard of a MM part not fitting unless something was messed up on the car the part was going on.
Old 05-17-2015, 01:08 AM   #4
Well it didn't fit right for some reason. I wasn't expecting it either. Looked everything over a whole bunch if times and it was installed right. Had to make the hole the adjuster goes in the firewall a bit bigger and it sat a little lower and didn't hit on the other side anymore. Works great now tho
Old 05-17-2015, 08:18 AM   #5
I've always used the Fiore adjuster myself, curious as to whether this MM one you have is a click style adjuster or does it have a set screw? I hate set screws.
Old 05-18-2015, 06:34 AM   #6
The Maximum Motorsports clutch cable kit is my favorite all time aftermarket part i have ever used. Best clutch feel ever!!!!!!!
When you experience clutch issues and even get stranded on side of the road, when you find a fix that is so much better than stock or anything else tried in place prior, it is appreciated 10X more.
The Cobra is going to have the clutch replaced with a McLeod clutch kit. Im also installing new FRRP TO & Pilt bearings, MM clutch kit, billit TO bearing sleeve/tube,
and clutch fork with new adjustable pivot ball.
SOME LINKS:
The T45 Source - Proven, reliable T45 Transmissions
Old 05-18-2015, 10:35 AM   #7
SOME LINKS:
Get OEM TOB/Pilot, not FRPP, they are not the same. You need to get the TOB/Pilot from a dealership. Tousley has good prices on them.
Old 05-21-2015, 08:01 AM   #8
So I adjusted it quiet a bit to where there is almost no slack at all, I'm still getting a little vibration in the pedal. More apparent with increased rpms. I'm scared to over adjust it and wear out the clutch or de story my transmission. Any ideas?
Old 05-21-2015, 08:50 AM   #9
That vibration is indicative of something in the clutch being not quite right honestly. Clutch pedal should not vibrate.
Correct way to set the preload up with a firewall adjuster is to actually be looking into the bellhousing through the clutch fork opening while the car is running in neutral. If the TOB is not spinning, tighten the adjuster up until it starts to spin and then go a little tighter and there you go. If its spinning already when you look at it, back it off till it stops and then do the above process.
Old 05-21-2015, 09:24 AM   #10
Yeah I'll have to do that. But the thing is I am sure everything is installed correctly. If u by chance read my other post about all the troubles I had in installation, by the 5th time I installed everything I'm 100% sure everything is correctly installed lol
Old 05-21-2015, 10:14 AM   #11
And again it's only on the slack of the pedal and then it's perfectly smooth. Everything is torqued to exedys specs also
Old 05-22-2015, 02:51 PM   #12
Thank You-
I am going to start over with my research since you mentioned it.
The M#on my FRPP bearings are exactly the same as on the Ford bearings.
I will double check, last time i questioned it, NO ONE WOULD ANSWER ME!!!!
Thanks for your advice.
Old 05-24-2015, 10:16 PM   #13
Ok so did what you said about adjusting it. Tightened it until the tob started spinning and the. A couple more turns. Took if out for a drive and still got the same vibration in the pedal. Got pissed off and did a 5000 rpm shift (300 miles on new clutch). After that the pedal started vibrating a lot more apparent. Vibrated enough to make the pedal sit there and click.
After getting it home I turned the car off and felt the pedal. Pedal was a lot harder to depress and made a click sound coming from the bell housing when it got past a certain point. And after starting it to pull it In the garage the grabbing point was right off the floor. Before it was about 3 inches up id say.
I jacked the car up and took the dust cover off the transmission. The clutch fork had somehow slid out of the set point on the ball. After pushing the fork in you could tell it reset in it's proper position back in place on the pivot ball, the clutch felt normal again and the clicking sound was gone.
I am now thinking my pedal vibration problem is due to the pivot ball/clutch fork. It was worn when I disassembled it but I thought it wasn't giving me any problems before, I'm not gonna **** with it. If I tear this apart again I am going to go with all oem everything. Gonna replace this ford racing tob and get a oem one and same for fork and pivot ball.
What do you think?
I
Old 05-25-2015, 11:49 AM   #14
What's the absolute best throwout bearing I can get? Oem?
Old 05-25-2015, 02:49 PM   #15
OEM Ford throw out bearing appears to be the same as the FRRP bearing.
Tousley Ford:
F7ZZ-7548-AA BEARING
MANUAL TRANS
BEARING for 1996 Ford Mustang|F7ZZ-7548-AA
My FRRP TO bearing has same part number.
On the bearing it'self, "614014" is stamped onto it.
So, I'm still not sure what the deal is with that.
I have both FRRP TO bearing and pilot bearing to go on when McLeod clutch kit goes on. MM clutch cable kit, TO bearing sleeve tube, adjustable pivot bolt, FRRP fork, all to work together as a cohesive unit. Can't wait!!
Old 05-25-2015, 04:29 PM   #16
So was driving around a bit today and the fork slid off the set point on the clutch fork again... Any other possibilities this could be? Where do I find oem fork, tob, and pivot ball also? I don't want to get ford racing stuff in accident again
Old 05-25-2015, 04:42 PM   #17
Buy everything from tousley.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 05-26-2015, 02:08 PM   #18
Good Idea to also go to my local ford dealer and order them? I think they would be able to get them next day
Old 05-26-2015, 02:10 PM   #19
See what the prices are, you won't have to pay for shipping. There is a badass dealer right where I used to live that I still go to. I'm actually heading out there for a few things this week. They sell a lot of FRPP stuff as well as Steeda and Roush too.
Old 05-26-2015, 02:11 PM   #20
And where can I find the input shaft retaining sleeve? The part the throwout bearing slides on. I can't find oem anywhere
Old 05-26-2015, 02:16 PM   #21
For the sleeve you actually want FRPP.
Your Google-Fu is weak...
Old 05-26-2015, 02:24 PM   #22
Well **** I was looking for only oem **** lol wasn't seeing it on tousley thanks man
Old 05-26-2015, 04:19 PM   #23
Wait, **** you don't have a T-5 DO NOT BUY THAT!
I got it in my head that this was for a SN95 with a T-5 for some reason... I'm truly sorry if you've ordered it already, call AM and they'll cancel.
Let me know what trans you have and I'll link you to the correct sleeve.
Old 05-26-2015, 04:37 PM   #24
Nah I haven't ordered yet no worries, I've got the 3650
Also should I switch from royal purple transmission fluid? Been reading it's hard on the synchros in the 3650. I want to get the best
Old 05-28-2015, 02:06 PM   #25
Went ahead and ordered everything from local ford dealer simply for the fact it would be here tomorrow and I can work on it this weekend. Also, tousley's site says you have to call them to see if they have everything in stock and their number was disconnected. I got the clutch fork, pivot ball, oem tob, tob retainer, and new flywheel and pressure plate bolts.. 330$ later... If this doesn't fix my issue I quit at life
Old 05-28-2015, 02:10 PM   #26
You got the 3650 sleeve? Everything I was seeing is that the 3650 one is non-available or only on a new trans which I did find hard to believe because then where do the rebuilders get them?
I found a bunch of T-45 stuff tho lol.
Old 05-28-2015, 02:12 PM   #27
I'm assuming the dealer got the right thing. 3650 came on all 02 gts correct?
Old 05-28-2015, 02:13 PM   #28
Yes it was the only stick shift trans that year.
Old 05-28-2015, 02:20 PM   #29
Then I'm assuming they got the right one. I guess I'll find out tomorrow. Should I keep using royal purple transmission fluid or switch to a better one since I'll be draining it yet again
Old 05-28-2015, 02:24 PM   #30
I like Pennzoil Synchromesh. Word on the street is that Royal Purple eats blocker rings in these transmissions but I have not seen anything official from any manufacturers on that.
Old 05-28-2015, 03:27 PM   #31
Ok sounds good man. This has been the story of my life with both my mustang and my 4Runner this past month lolClick image for larger version
Name:	ImageUploadedByMustang Evolution1432848457.252497.jpg
Old 05-29-2015, 11:47 AM   #32
Everything else looks correct but they must have misunderstood me when I was talking about the input shaft/tob sleeve. This is what they gave meClick image for larger version
Name:	ImageUploadedByMustang Evolution1432921573.170308.jpg
Idk they might be discontinued for the 3650 like you said Scott.
Old 05-29-2015, 07:55 PM   #33
That's for a T-5. Send it back and make them pay return shipping.
Like I said, everything I'm seeing says they are not available separately... hmmm...
Here give this a shot. Owner is named Stan
Pro-Force Performance; Specializing in Rebuilt Mustang Manual Transmissions in Atlanta, GA
If anyone is going to be able to get you a new sleeve its this guy.
Old 05-30-2015, 04:04 AM   #34
YOU HAVE GOT TO BE KIDDING ME!!!!! Stayed up till 4:30am installing everything I bought today, oem clutch fork, oem throwout bearing, oem pivot ball. SAME ****
So now I have installed:
exedy mach 400 clutch kit
Maximum motorports adjuster/ cable kit
Oem throwout bearing
Clutch fork
Pivot ball
Resurfaced flywheel
What the hell else could it be?!?!? I'm beyond fed up with this. Ughhhhhhhh
Old 05-30-2015, 06:21 PM   #35
I went through the same thing on my 96 gt. Best advice I can give is to pull on the cable with your left hand and turn the adjuster until there is about a dime width gap between adjuster and cable assembly. Than just go and drive your car for a while. You may have to adjust it again that's ok. I had to re adjust mine like three times and I can say after about 4k miles the vibrating is pretty much gone. Than again I don't usually leave my foot on the clutch while I drive.
aero86 is offline   Reply With Quote
Is the firewall adjuster worth the wait?? 351stroker 1979-1995 Mustang GT 1 09-28-2013 09:08 AM
Quadrent and Firewall adjuster?.. sixpac 1996-2004 Mustang GT 10 09-20-2013 07:54 PM
Best firewall Adjuster? sixpac 1996-2004 Mustang GT 3 06-08-2013 10:47 AM
Needing a new firewall adjuster SpectorV Pre-2005 V6 Mustang 2 10-13-2005 12:56 PM
Maximum Motorsports steering rack bushings fastmustangs1 Pre-2005 V6 Mustang 1 10-22-2004 04:16 PM
06:15 PM
