5.4 heads on 4.6 block - Mustang Evolution
Old 05-18-2015, 12:39 AM   #1
Send a message via MSN to santanabori
Hi guys I have a pair of 5.4 heads im planing to put on my 2000 gt. If any difference or do I need to make a.change. also can I leave the cams ordo I need to.change them for the 4.6? Thank you
santanabori is offline   Reply With Quote
Old 05-18-2015, 06:05 PM   #2
5.4 and 4.6L heads are the same, so are the cams. Blocks are different. However... make sure the heads you have are PI heads. Mustangs went to PI heads in 99 but some vehicles including some of the trucks did not until a few years later.
There are also Windsor vs Romeo heads but they are all compatible except you need to have Windsor valve covers for Windsor heads and Romeo valve covers for Romeo heads. Windsors have 13 valve cover bolts, Romeos have 11.
Old 05-19-2015, 05:51 PM   #3
Panther140's Avatar
Unless you have a 99 or 2000 mustang GT, you are going to need different timing covers to make that work. ALl of the 5.4 engines were made at the Windsor plant. Most of the mustang engines were made at romeo, but the 99 and 00 were windsor. Not sure about 96 and 98 though
Panther140 is offline   Reply With Quote
Old 05-19-2015, 05:58 PM   #4
No, he just needs the correct size hardware. I'm putting a 2000 cover on a 2005 for example, it bolts right on with the correct bolts.
Old 05-19-2015, 06:05 PM   #5
Panther140's Avatar
Oh I see. I thought there was another slight difference in the tensioner for some reason.
Old 05-19-2015, 06:08 PM   #6
WJL
When you say correct bolts what do you mean, longer, shorter, larger diameter or thread type ?
Is this true for a 1998 as well
WJL is offline   Reply With Quote
Old 05-19-2015, 06:09 PM   #7
Panther140's Avatar
The cams are also different in some ways, but still interchangable. One plant pressed the cam gears on, the other bolted them
Old 05-19-2015, 06:22 PM   #8
Romeo heads and Windsor heads use a slightly different size bolt where the timing cover attaches to them. I'm just going to use the stuff that came with the Marquis motor I got, if that doesn't work then its a trip the the hardware store.
Bolt hole locations are the same. I'm just swapping everything on the front assembly from my 2000 Windsor to my 2005 Romeo because I don't feel like having to guess at the blower mounting and the blower belt tensioner and routing.
Old 05-20-2015, 01:27 PM   #9
WJL
Got it, i will learn more i guess when i pick up my 05 Lincoln Motor Saturday, Thanks
Old 05-20-2015, 02:46 PM   #10
Keep all the hardware from your 2000. Swap everything from the Mustang from the cover to all the accessories and tensioners over to the 2005 "Vic" 2V you are getting. Even if it was the same year as your mustang the accessories are different. You may even have to swap the water pump which is a good excuse to replace it unless its real low mileage, then just a new gasket and go.
Old 05-21-2015, 11:57 PM   #11
Thanks guys how about the cams this is from an expedition do you think they'll work good? Should I leave them? Or should I changed them for the 4.6?
Old 05-22-2015, 12:11 AM   #12
natestang07's Avatar
Swap the cams and the intake manifold
Old 05-22-2015, 09:49 AM   #13
Cams should be the same, you can't use the truck manifold.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 05-22-2015, 10:41 AM   #14
The cams are the same in the expy?
Old 05-22-2015, 11:42 AM   #15
I believe so but not 100%. PI cams are PI cams. I do not think they are different in the trucks but he can always just swap his cams if he's worried about it. Manifold for a 5.4 is wider though, not compatible and I don't even like using lower mileage used PI manifolds honestly. They all warp under the tstat housing and leak after awhile. Although a new FRPP one will last a good while.
Old 05-22-2015, 11:44 AM   #16
There in lies the problem. I didn't realize the expy and trucks got the pi treatment.
Small block big block discussion @ work ReggStang 2005-2010 Mustang GT 6 07-15-2012 03:16 PM
4.6 npi block with pi heads Rexxx73 1996-2004 Mustang GT 4 07-06-2012 09:11 PM
4.6 npi block with pi heads Rexxx73 New Member Introductions & Greetings 0 07-06-2012 12:22 PM
small block/ long block blackGT91 1979-1995 Mustang GT 15 05-14-2012 09:21 PM
5.0 block vs 4.6 block 98RedGT 1996-2004 Mustang GT 4 06-13-2011 12:03 PM
11:35 AM
