04 GT codes - Mustang Evolution
Old 05-18-2015, 08:43 AM   #1
XSlashDashX's Avatar
04 GT codes
Pulling p0300 and p0316. It's a misfire, correct? One code says misfire at start up but doesn't feel like it's missing.
Old 05-18-2015, 11:31 AM   #2
Probably a bad coil pack
nintysixstanggt is offline   Reply With Quote
Old 05-18-2015, 11:55 AM   #3
Yep. Misfire.
First, check your charging system.
If that checks out good, start with checking for vacuum leaks of un-metered air entering the intake.
Also, any or all of the basic tune up items can cause these codes.
Old 06-15-2015, 04:06 PM   #4
Checked my charging system. All tested good. Changed out plugs and runs a whole lot better but still having the random misfire code at start up (3000 revolution). Tested fuel injectors and they came out good. I guess I'm down to the coil packs. I can hook a voltmeter to coil pack and test like that? Because my car is cam and i cannot tell by unplugging 1 coil at a time.
Old 06-15-2015, 04:11 PM   #5
You need a more sophisticated piece of equipment, to test the coils, than a multimeter.
Did you check for vacuum leaks?
Old 06-20-2015, 10:34 AM   #6
No, haven't checked for vacuum leaks. I switched over to 93 octane and no codes are popping back up. And idles a lot more better than it did. I don't know if it affects from 87 to 93. I bought this car used so i couldn't tell you if it has been tuned or not but by switching to 93 i think it does. It also has LT headers and cams if that affects anything.
Old 06-20-2015, 10:54 AM   #7
The car must be tuned if it has anything more than what would be considered as "stage 1" cams.
I wouldn't have thought that too low of octane would cause a misfire but if the code has gone away... Then it's fixed!
What is the difference between these paint codes..... domin8stang Mustang Audio & Video 3 11-02-2003 02:23 PM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 1 08-03-2003 08:24 AM
EEC - (Error Codes) dark Pre-2005 V6 Mustang 0 08-02-2003 07:42 PM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 2 07-30-2003 12:22 AM
02:20 PM
