Start up issue - Mustang Evolution
Old 05-18-2015, 04:58 PM   #1
BeastyStang's Avatar
Start up issue
I have recently developed two issues with my car. One, being minor. The other, is a little more serious you can say.
One, my battery light recently just came on thinking that it was time for a new battery. Cool, i first charged it and the next day the battery was completely dead. So, i replaced the battery and the starter at the same time and the light is still on. Mind you i replaced these months ago and I rarely drive the car. It doesn't affect anything in the car, but it sure is annoying. A couple a weeks ago, i had my boy scan it and I got the code of B1318. I googled it, and it sure is something electrical. But after reading other people's symptoms, they are not the same as mine. Again, my car seems to be okay. Radio works, lights, work everything works fine.
Second, after my intake manifold was replaced there are times when i try starting it up, the car just turns and doesn't start up. After a few seconds i try turning it on, and it fires right up. After it starts up, it makes like a weird gargling noise. I would post up a video but i have it parked at my cousins house right now.
Do any of these two issues seem common? Other than these two issues, my car runs fine. But of i could prevent something serious from happening i'd like to take care of that immediately.
BeastyStang is offline   Reply With Quote
Old 05-18-2015, 05:35 PM   #2
fenixignition's Avatar
if your battery light is on, i usually suspect the alternator. the battery light usually comes on when the voltage is at or below 12.9 volts. maybe 13, not sure. its supposed to be at 14v when the car is running and the alternator is working. a bad alternator has led to all sorts of codes, such as the cam or crank sensor. changing the alternator usually fixes these if it isnt actually the sensors.
as for the intake manifold, we need more info. was it used? was it an autoparts store brand like dorman? or direct from ford? (Ford Racing PI intake manifold)
2002 GT 5sp. 16x,xxx miles
Old 05-18-2015, 05:39 PM   #3
natestang07's Avatar
On my old Nissan I had the plug to the alternator wired backwards and it caused my abs light and battery light to stay on. No ill effect besides that
Old 05-18-2015, 06:24 PM   #4
Hmm...i would definitely have to check the alternator out.
As far as the manifold goes, i replaced it with an oem one. It has the ford stamp on it. I really need to post up that video. I should have that up tomorrow.
Old 05-18-2015, 07:00 PM   #5
It is a long shot but is possible if you have been messing with it abit
Old 05-19-2015, 06:53 AM   #6
gargling noise, is it coming from the tailpipes or the engine bay?
its possible that a bad gasket was put on it.
Old 05-19-2015, 11:37 AM   #7
Lorraine's driver
ab_mach1's Avatar
If you end up replacing your alternator, make sure you charge up your battery before starting the car up for the first time. The low voltage is hard on the alternators.
Instagram: @ab_mach1
Old 05-20-2015, 06:08 AM   #8
Yes. got many of these exchanges working at advance autoparts.
Remote start/push to start GT_Man 2011-2014 Mustang GT 9 01-31-2015 11:57 PM
Thought I'd share pics of my successful Push-to-Start/Remote start install! Jordan.Cortina General Mustang Discussion 32 01-30-2015 08:29 AM
Cold start idle issue. FutileTerror9 1979-1995 Mustang GT 3 06-10-2013 07:36 AM
intermittent start up issue Terminator 2005-2010 Mustang GT 11 04-05-2013 08:24 PM
Cold Start/ Idling issue CodyNelson 1996-2004 Mustang GT 11 09-24-2011 10:34 AM
07:29 PM
