shaky steering wheel/wandering - Mustang Evolution
Old 05-19-2015, 04:39 PM   #1
robin_gt's Avatar
Hi folks,
so I've had this problem for quite a time now and i think it's time to tackle it.
When i travel at highway speeds the car will wander a little across the lane and the steering wheel feels kinda loose in general. I took a video of the steering rack today and it moves a little bit if i turn the steering wheel. It makes a weird but not loud crunching kinda noise after i turn the wheel and let it sit(it will make the noise for like 2 seconds and then it will go away.
Has anyone ever had this problem and/or fixed it? New bushings and bumpsteer kit are coming in tomorrow. Should i just go ahead and replace the whole rack and pinion?
Thanks
robin_gt is offline   Reply With Quote
Old 05-20-2015, 05:17 PM   #2
robin_gt's Avatar
Anyone?
Old 05-20-2015, 05:53 PM   #3
I did my rack bushings (along with everything else!) and it cured the wandering problem. Again, I replaced EVERYTHING in the front end. The rack bushings were definitely toast on my car though.
Do a thorough inspection of all the bushings, tie rods, ball joints, wheel bearings, everything in the front end that moves!
Old 05-20-2015, 06:10 PM   #4
robin_gt's Avatar
thanks you for answering
yeah im gonna replace the bushings and a bumpsteer kit is going in.
i replaced the ball joint just recently.
installing everything this weekend ill keep you posted if it helped.
Old 05-20-2015, 06:20 PM   #5
I think that those bushings will probably help a lot. The one on the drivers side gets soaked in oil and deteriorates pretty bad.
Keep us posted!
Shifting is shaky njdurkin General Mustang Discussion 7 03-12-2014 04:22 PM
Wandering Steering, Please Help Michael.s.king General Mustang Discussion 7 02-11-2014 01:19 PM
Wandering idle Fballman9 1979-1995 Mustang GT 4 01-06-2014 12:26 AM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
1994 Mustang Gt Manual Trans. Shaky on the gears.? huntington 1979-1995 Mustang GT 1 08-26-2009 04:44 AM
08:36 AM
