2001 Mustang GT tranny question - Mustang Evolution
Old 05-19-2015, 07:05 PM   #1
Robbymyman's Avatar
Alright, basically I though my transmission was going out but after driving around and tinkering with the controls I think I've boiled it down to the O/D clutch.
This is because when O/D (Overdrive) is engaged and I am a speed where it kicks in its does nothing but rev. Meaning of I am in 4th gear (overdrive gear) and I accelerate, nothing happens but the Roma go up. So it's acting as if it's in neutral, which it might be however I find that unlikely. When O/D is off it drives just fine, minus the high Rpms, even if I want to jump off a line and redline line it, it drives and shifts just fine.
So what do you guys think? Is it the overdrive clutch? If so, what's the cost in replacing those? Or where to even buy one?
*i am having my mechanic check it out tomorrow and replace the filter along with the fluids and all. But I feel it will not help if it is the clutch.
Robbymyman is offline   Reply With Quote
Old 05-19-2015, 07:17 PM   #2
natestang07's Avatar
The overdrive band is typically associated with another gear as well. Like on my 07 when my band went out I lost 5th and second. Sounds like your 5th gear is gone for sure
Old 05-19-2015, 07:24 PM   #3
Robbymyman's Avatar
It's an automatic, it only has 4 gears, and thankfully the gear that went out was the overdrive gear. I haven't had any issues with any of the other gears, it's just like 4th gear decided to turn into neutral.
Old 05-19-2015, 09:24 PM   #4
Panther140's Avatar
could be a valve body issue also couldnt it? How are your fluid levels?
Panther140 is offline   Reply With Quote
Old 05-19-2015, 09:26 PM   #5
Could be. The fluid change will be telling
Old 05-20-2015, 03:42 AM   #6
Slater2111's Avatar
We can eliminate oil issues real quick, go smell the tranny oil. If it smells burnt it'll be part of the problem. Not saying it will be all of the problem. But burnt oil can cause similar symptoms.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 05-20-2015, 06:39 AM   #7
Robbymyman's Avatar
Possibly the valve body and The fluid level isn't low, however I am getting it changed today hopefully along with the filter.
2001 mustang
Auto tranny VS. Manual tranny x2bittz Classic Mustangs 15 06-29-2013 07:07 PM
Matts 2001 V6 Coupe :: 2001 Ford Mustang fastmustangs1 Member Garages 0 03-24-2013 11:22 PM
v6 tranny to a v8 tranny 97V6stangct Pre-2005 V6 Mustang 4 02-04-2012 12:42 PM
My baby :: 2001 Ford 3.8 2001 coup Cjkingsman Member Garages 0 06-15-2011 12:01 PM
2001 Auto Tranny Hesitant Shifting OsirisGuy Pre-2005 V6 Mustang 17 11-14-2008 06:35 AM
04:25 AM
