AC delete questions - Mustang Evolution
Old 05-19-2015, 08:44 PM   #1
AC delete questions
Alright my air conditioning has never worked and i'm way too lazy to fix it and don't want to pay someone to so i'm thinking of just deleting, i also drive windows down 90% of the time anyway.... Right now i'm thinking of just pulling the compressor and putting in one of the delete kits from like AM for $40.
If i pulled the whole entire system how hard would it be to put back in if i ever wanted to for some reason. What are all the parts that are included in an AC system? I'm new to AC.
Also, anyone know how much just the compressor weighs? Can't find consistent answers. Gotta get some weight off this front end.
Old 05-20-2015, 06:43 AM   #2
Tyoung68's Avatar
It may be a good idea to get it diagnosed first before you rip everything off. Most places will do it for free. That way after you take it all off you'll know what to keep/replace if you do put it back on. Most of it is pretty strait forward just unbolt and remove, you with need an A/C line disconnect tool which are pretty cheap. And putting it back on is just as easy as taking it off + a recharge. Also would probably be a good idea to have a shop empty the refrigerant before removing everything.
Old 05-20-2015, 08:08 AM   #3
In pretty sure there is no refrigerant left in the system.... If I do this it'll be after I get a DD so that'll have AC and this will be more performance focused.
Old 05-20-2015, 12:10 PM   #4
Slater2111's Avatar
Well you have no ac now sooooo... Why not. Lol I think the whole system together removes approximately 30 pounds or so lines and all.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 05-20-2015, 12:21 PM   #5
I'll bet that the compressor, and the evaporator, weighs at least 15-20 lbs.
Like Travis said, the installation is the reverse of the removal. And it would be helpful to know what is wrong with it, should you ever want to reinstall the system. That way you aren't bolting on broken parts.
Old 05-20-2015, 01:20 PM   #6
WJL
I removed mine, took less than an hour to do the whole thing, and like you the refrigerant had already escaped.
I have the ford racing delete kit my only complaint is the pulley is plastic I've heard there are better metal pulley's available.
I not only removed the compressor but i took all the hoses off as well, same tool you use to disconnect your fuel lines you can buy a complete set for under 10 bucks.
I sealed the hose connector at the fire wall just in case i ever decided to go back to AC just so nothing like dirt or debris gets in there.
It makes a lot of room on the right side once it's out.
WJL is offline   Reply With Quote
Old 05-20-2015, 01:43 PM   #7
Ok. So not all too hard to take out and put back in? I'm fine taking the whole thing out. Just want to know i would be able to put everything back in IF for some reason i ever do (I don't plan on it)....
One thing i do need is heat though. I can deal with no AC but in winter time i need heat and window defrosters lol.
Old 05-20-2015, 01:48 PM   #8
The heat will still work but the defrost function is aided by the A/C system. The defrost will work, just not as effectively.
Old 05-20-2015, 01:50 PM   #9
Hmmmm. On a scale 1-10 how effectively would it work compared to stock?
Old 05-20-2015, 01:59 PM   #10
natestang07's Avatar
How cold does it get down there typically?
Old 05-20-2015, 02:00 PM   #11
Lol.
I don't know, on a scale of 1-10 but the defrost will work exactly the same as a vehicle that is not equipped with A/C.
It still works OK but it will be much slower and under certain conditions you will have to leave it on constantly.
The A/C helps to dry out the air.
In the CA climate it isn't really an issue.
Old 05-20-2015, 02:03 PM   #12
And actually, if your A/C hasn't been working, you won't notice any difference.
Old 05-20-2015, 02:05 PM   #13
Not very!
Nothing like up North where you live. We get some frost every once in a while but the winters are generally pretty mild.
Old 05-20-2015, 02:07 PM   #14
Originally Posted by straybullitt View Post
Not very!
But you do occasionally get frosted over and whatnot? Not a bad deal.
Old 05-20-2015, 02:17 PM   #15
Only 1 or 2 days out of the year i have to worry about the windshield icing over. Other than that its generally just fogging....... And the car is covered all the time so i actually don't really even need the defrosters anymore. I just don't want to be SOL if it does fog over lol.
Screw it i'm just going to rip that **** out.
Old 05-20-2015, 02:21 PM   #16
It didn't seem to be as cold this winter as last year. I live at a little higher elevation than Andrew and we actually got some snow last year!
I couldn't live without the A/C in the summer though. It gets way too hot where I am!
Old 05-20-2015, 02:22 PM   #17
We usually get a lot of snow and only had snow on the ground for about 2 weeks. Alrefire had more snow in Alabama than us lol
Old 05-20-2015, 02:23 PM   #18
I live in the bay area so its generally mild climate. Even in Sacramento its manageable without AC. I mean i would like to have it, but i've gone over 2 years without working AC so at this point i think i can deal with it..... Plus i'm looking into getting a cheap DD. I'll have a car port at my apartment next school year so i'm going to convince my roommates to let me have it......
Now the question is. How much do i want to rip out the heater core? I'll see how the AC goes and if i do get a DD then i'll consider it. Really want to take weight off this front end.
Old 05-20-2015, 02:25 PM   #19
So it doesn't really get too hot there? That surprised me. We see mid 90s and triple digits throughout summer here.
Old 05-20-2015, 02:36 PM   #20
In Sacramento it can get to 100 + or - 10 degrees. At school though where i spend most of the year its 90ish give or take......
BUT, i spend summer in Sacramento, and i have the garage during that time, and the part i hate the most is getting in the car when its already hot, if i get the garage and then drive in the heat i don't care too much since windows are down.... I go back to school September 1st and its already cooling down. So i have pretty awesome weather year round.
Old 05-20-2015, 02:36 PM   #21
It gets pretty warm in places inland, but all along the coast you get the sea breeze from the Pacific Ocean that provides free "air conditioning" both winter and summer. Where I used to live, in the Monterey bay area, it has probably one of the mildest climates on earth!
Old 05-20-2015, 02:40 PM   #22
All about that weight reduction lol. 3335 right now with 1/2 tank. I wonder if i can get into the 31xx with race seats, sound deadening removal, AC delete, heater core removal, and tubular bash bar. I also want to take out my window washer tank. I already emptied it, but want to remove it also since i have never once used it.
Old 05-20-2015, 02:44 PM   #23
Sound deadening is heavy for sure. Do you have any gone yet? I swear I read that stuff is good for 100-200k pounds
Old 05-20-2015, 02:44 PM   #24
Planning on taking it out when i swap out my seats since they gotta come out anyway for it. As soon as those come in i'm stripping the interior.
I guess this leads to my next question..... What's the easiest way to remove the heater core in a new edge?
Old 05-20-2015, 02:53 PM   #25
You have to remove the dashboard.
If you remove the heater core, the heater nor the defrost will not work.
Old 05-20-2015, 03:11 PM   #26
Yea I might wait on the heater core until the car is permanently garaged. I'll see what my weight is after a few things and see what else I want to do.
Old 05-20-2015, 03:36 PM   #27
Yeah. When you get ready to do it, you can just remove the entire HVAC box. It probably weighs around 5-10 lbs with everything in it.
Old 05-20-2015, 03:41 PM   #28
Well this is a rough estimate of what i can cut:
Race seats - 50lbs (25 each)
Sound Deadening - 40lbs
AC - 40lbs (from what i can gather on the inter webs)
At that point it is roughly 130lbs. Which will put me at 3205 pounds with 1/2 tank. Been debating on the speakers and ratio, but i do use that a lot so most likely not for a while.
Old 05-20-2015, 03:47 PM   #29
Hmm... Passenger air bag maybe? How much does that weigh?
Old 05-20-2015, 04:01 PM   #30
idk but i still drive people around at times lol. For now i want to be low 3200s or high 3100s. Ultimate goal after engine swap and tubular suspension is under 3k.
Old 05-20-2015, 04:03 PM   #31
What about the trunk? I know the thing that covers my dumb *** spare tire is a solid 10 pounds.
Old 05-20-2015, 04:39 PM   #32
AC delete questions
Trunk is gutted. I need weight off the front end most of all to balance it out.
Old 05-20-2015, 04:42 PM   #33
I'm assuming all of that felt crap is out of the underside of your hood
Old 05-20-2015, 04:44 PM   #34
AC delete questions
Actually no I haven't taken that out.... Planning on it though. Can't weigh more than a pound or two.
Old 05-20-2015, 04:48 PM   #35
Not sure how much more you can pull lol
Boss foglight delete questions Bigshow14 2011-2014 V6 Mustang 14 11-20-2014 10:13 AM
Wiring and heat delete questions busaboy 1979-1995 Mustang GT 3 02-28-2014 09:02 AM
Cat Delete Questions Defiant 5.0 2011-2014 Mustang GT 24 09-03-2013 05:50 PM
Power steering delete and ac delete Speed_Mister 1996-2004 Mustang GT 26 03-22-2013 02:14 PM
PCV delete questions wendyc Pre-2005 V6 Mustang 10 02-06-2005 10:14 PM
11:56 AM
