Random idle on startup - Mustang Evolution
Old 05-20-2015, 02:02 PM   #1
alecas447's Avatar
Ok guys first time this happens so a bit worried. Just got off work and when I dated it up it idles at 1k but it just stay there. Doesn't feel like the car is revving.
What can this be I took the pic with clutch depressed to see if it went away it didn't. Any thoughts?Click image for larger version
Name:	ImageUploadedByMustang Evolution1432152162.457746.jpg
alecas447 is offline   Reply With Quote
Old 05-20-2015, 02:08 PM   #2
natestang07's Avatar
Any new codes associated with it? How long did it stay up there? Could be tps or iac
Old 05-20-2015, 02:15 PM   #3
alecas447's Avatar
I personally don't think is the iac because it just stay there and doesn't rev.
---------- Post added at 04:15 PM ---------- Previous post was at 04:14 PM ----------
What's tps?
And not sure I would have to go get it read
Old 05-20-2015, 02:16 PM   #4
What about the code situation?
Old 05-20-2015, 02:46 PM   #5
alecas447's Avatar
Just went to the gas station and it went away idk maybe she was thirsty
Haven't checked the codes
Old 05-20-2015, 02:54 PM   #6
It should idle up there on a cold start for awhile
Old 05-20-2015, 03:04 PM   #7
alecas447's Avatar
really? maybe i just never noticed.
Old 05-20-2015, 03:48 PM   #8
Yeah my cold start sticks up at about 1250 for a little while.
Old 05-20-2015, 08:59 PM   #9
alecas447's Avatar
Hmm I'll see in the am. See if it does it then
Old 05-21-2015, 05:53 AM   #10
fenixignition's Avatar
yea thats pretty much what mine looks like at a cold start. It doesnt drop to the normal 700rpm until the temp gauge begins to budge. maybe a little before that. if the engine is warm at its standard 190-210 range (usually 200) and it still idles at 1k, then i would start worrying about it. let us know.
2002 GT 5sp. 16x,xxx miles
Old 05-22-2015, 10:22 AM   #11
alecas447's Avatar
Hasn't done it again. I knew I've never seen that before. Oh well who knows what it was
Old 05-22-2015, 10:24 AM   #12
i cant remember if an emmission code would cause the high idle, but its possible. coulda just been a fluke. Try to read the code as soon as you can when it happens. better yet, run to an auto parts store, and get it checked anyway. sometimes the code will store as "Pending" for a while with no light.
Old 05-22-2015, 10:25 AM   #13
alecas447's Avatar
Yea I totally forgot. For now I should just have the 2 cat codes.
Old 05-22-2015, 10:27 AM   #14
i wanna say that might cause a high idle, i know the computers try to do things to prevent too much polution, and that could equal running hotter to burn off more stuff in the engine? similar to the concept of hanging idle's having to do with emissions.
Random Rev from Idle Tytus 2011-2014 Mustang GT 13 06-11-2013 08:57 AM
random misfire at idle 1995 v6 95convertable Pre-2005 V6 Mustang 5 04-16-2013 08:52 AM
98 Mustang Manual 3.8L V6 - startup problems tinabfla Pre-2005 V6 Mustang 4 06-05-2011 09:42 PM
Hesitation at startup gtstyles2 2011-2014 Mustang GT 7 06-01-2011 07:20 AM
stalling on startup Deadmeat101 Pre-2005 V6 Mustang 4 09-16-2003 07:00 PM
06:26 PM
