Oil pressure gauge possibly failing. - Mustang Evolution
Old 05-22-2015, 05:47 AM   #1
fenixignition's Avatar
So when im driving, occasionally my oil gauge will drop to the red line (as opposed to all the way down when the engine is off). I just changed my oil, same oil as always, and 6 quarts as always. It was already doing this a little bit before, friend of mine said its just the gauge needing replacement. I am going to try and replace it today. I unplugged and replugged it when i changed the oil and it seemed like there was oil on the plug itself. so i cleaned it up. Seemed like it was doing better, now whenever i idle at warm, it seems to drop. if i rev it to about 1k or higher, it bounces back up, then when it drops to idle, the pressure gauge drops back down as well. When i am driving on the highway, sometimes it just drops again.
Also, I do know that it is an "Idiot light" and not a real gauge. So i am wondering, Is my pressure riding along 6-7 psi? Everything else feels completely normal. no engine noises, ticking, excessive roughness, all the same as it has been for the past 2 years.
Im gonna grab a pressure sender at the autoparts store today after work and try to swap it out before i drive 200 miles out of town. But given that there are no other symptoms, would you guys say that its likely just the gauge/wire/connection? or can 6psi just sneak up on you and kill your engine? I always imagined oil pressure that low would be very apparent. The oil is right in its normal range on the dipstick btw.
2002 GT 5sp. 16x,xxx miles
Old 05-22-2015, 10:19 AM   #2
Remember stock Guage is just an idiot light. You could test the sending unit if you checked it with a voltmeter making sure resistance is steady. If not that may be your issue. Not sure if a failing oil pump would cause these symptoms though.
Old 05-23-2015, 07:40 PM   #3
DetroitMuscle99's Avatar
Oil pressure sending unit. Change it. Does it drop to zero at idle. Also make sure there isn't oil on the sending unit plug itself.
This is why we play the game... to separate the contenders from the pretenders!
DetroitMuscle99 is offline   Reply With Quote
Old 05-23-2015, 07:43 PM   #4
Changed it today. And there was oil in the plug. Cleaned it and installed the new one. So far so good. But havent had the chance to give it a full test yet
Sent from my LG-D800 using Mustang Evolution mobile app
Old 05-23-2015, 07:43 PM   #5
alecas447's Avatar
Mine hasn't worked since I bought the car the battery or the temperature either.
alecas447 is offline   Reply With Quote
Old 05-23-2015, 07:45 PM   #6
Your problems fixed!
Old 05-23-2015, 07:47 PM   #7
Pull the bezel make sure all connections are plugged in. Check fuses.
Old 05-25-2015, 10:52 AM   #8
The stock gauge is an on-off switch. At 6 psi it goes to "normal" and below 6 psi it goes to 0.
Best advice I can give here is to get an aftermarket oil gauge. You don't have to pony up a ton of $$$ for an Autometer Cobalt or anything, I like Speedhut and the prices are fair and the gauges look GREAT. Aftermarket guage will tell you exactly what PSI you are at and you can T the oil press sender to keep the stock gauge from being dead if you want.
Old 05-25-2015, 10:54 AM   #9
Rapinator126's Avatar
Automater cobalt here. Besides the aeroforce. Worth the $
New oil pressure sending unit, still 0 oil pressure Iryan7 Pre-2005 V6 Mustang 9 07-13-2015 03:15 PM
Fuel pump failing? 2000 Mustang Gt 1996-2004 Mustang GT 4 07-12-2013 04:31 PM
Failing Elastic Band Conv Top Gk1million 2011-2014 V6 Mustang 0 11-12-2012 01:57 PM
95 mustang gt 5.0 failing 1 test in emission high nitro oxide plz help durtyred69 1979-1995 Mustang GT 4 06-13-2012 11:38 PM
Cats failing? austinknoll Pre-2005 V6 Mustang 9 03-20-2012 01:54 PM
10:07 AM
