2000 mustang gt wont turn on!!! - Mustang Evolution
Old 05-22-2015, 06:31 AM   #1
I have a 2000 mustang gt and It's been sitting in my garage for more then 9 mnths. It started up fine all that time till a month ago I started noticing a hissing noise coming from the fuel cap. From there on I had trouble turning it on until one day it didn't start up. The only way It started up was with starting fluid. I changed the fuel cap and fuel filter and now it won't start and when It does you hear the gas tank sucking in air and it making thump like sounds. I checked the spark plugs and they look like charcoal. Idk if thats the problem I'm going to replace them today.i need help guys please!!
friscogt415 is offline   Reply With Quote
Old 05-22-2015, 07:01 AM   #2
fenixignition's Avatar
are you turning the key to the on position and waiting for the pump to prime? it could be a failing fuel pump, especially if starting fluid is starting the engine.
2002 GT 5sp. 16x,xxx miles
Old 05-22-2015, 07:38 AM   #3
so change the fuel pump?
Old 05-22-2015, 07:40 AM   #4
i would do a fuel pressure test first. listen for a noise when you turn the key to the on position before starting the engine. try turning the key to the on position a few times, then start it. see if it runs okay or if it eventually just dies.
also, how old is the fuel? any fuel additives mixed in there?
Old 05-22-2015, 07:46 AM   #5
I tried turning the key and no start. I put 2 gal of gas this morning. I put a thing of fuel injector cleaner like 2 weeks ago
2000 mustang
starter stuck wont turn off!!!! 87_Saleen 1979-1995 Mustang GT 4 03-11-2012 03:19 PM
Left low beam headlight wont work but i will when i turn on high beams p1blake04 1996-2004 Mustang GT 4 09-05-2011 10:30 PM
Interior Light Wont Turn Off ! scrimsmustang Pre-2005 V6 Mustang 26 05-10-2005 04:03 PM
engine wont turn over, help!! fast64 1979-1995 Mustang GT 9 03-21-2005 02:32 PM
Fog lights wont turn on whitev6stang03 Pre-2005 V6 Mustang 26 01-24-2005 05:34 PM
09:31 PM
