Damn idle. IAC/TPS problems? Idle screw? Help! - Mustang Evolution
Old 05-22-2015, 09:25 AM   #1
v8pony's Avatar
Hey guys, long story short, 2 weeks ago my car was idling way to high, before replacing things I messed with the idle set screw, which I am now 100% regretting. Well I had to change my IAC. After changing my iac I did the whole idle re learn procedure, as well as following cliffys guide to setting the TB idle set screw..well the problem I'm having now is my cars idle seems to be working JUST on that idle set screw, I'm idleing about 800-900 rpm, but when I unplug the IAC at idle NOTHING, when I unplug the TPS at idle NOTHING!! my IAC is 2 weeks old..I can unplug the hoses going to the IAC at idle, NO DIFFERENCE. What the hell is going on guys?! Its driving me crazyyyy. When i put my A/C on the idle dips down to like 600 and stays there!!! Wtf. Its like the TPS and IAC are bypassed somehow? They are both literally doing NOTHING for my idle, and whenever I use any accessories my idle just dips and stays there, it will not come back up until I turn that accessory off! Arghhh, this Fin car lol.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
2002 5spd GT
Feb 2013 Mustang of the Month
Old 05-22-2015, 11:16 AM   #2
fenixignition's Avatar
sounds like you need to loosen the screw so the valve can close a little more.
That sounds like what happened to me when i thought my iac was constantly bad. then realized the screw needed to be loosened just a bit. what plenum/throttle body do you use?
2002 GT 5sp. 16x,xxx miles
Old 05-22-2015, 01:47 PM   #3
v8pony's Avatar
If I loosen the screw than the idle is too low, when I put the a/c on it will die...its the stock TB/plenum..the IAC is a few weeks old, even when I attempt to plug in my old IAC, which wasn't entirely shot, nothing happens.
2002 5spd GT
Old 05-22-2015, 02:39 PM   #4
only other obvious thing i can think of would be checking for vac leaks. ive been using a bwd iac for years now, idles at 1000 when cold start up, 700 when warmed up (florida weather) and if i unplug the iac, it sounds like its going to kill over. i wanted to say that your iac is stuck open, but you mentioned the old one had the same results.
No check engine light?
Set Idle Screw / Idle problem v8pony 1996-2004 Mustang GT 8 05-15-2015 11:07 PM
Help Purchasing new IAC for my Fox ivan88GT 1979-1995 Mustang GT 5 05-26-2014 12:31 PM
damn it, damn it, damn it jimmy_beaner The Bar 15 07-01-2005 06:18 PM
possible IAC problem? HELP!? Horse Pre-2005 V6 Mustang 0 12-10-2003 01:59 PM
"Damn cops" and "Damn women drivers" fast64 The Bar 10 11-27-2003 08:18 PM
03:43 PM
