Oil change! - Mustang Evolution
Old 05-23-2015, 01:38 AM   #1
LeoGMR4558's Avatar
Oil change!
How often do you do your oil change and branddo you use and how much? And how much oil should be put in the oil filter?
LeoGMR4558 is offline   Reply With Quote
Old 05-23-2015, 04:13 AM   #2
Mile high JDF's Avatar
3,000 miles, I personally used Mobil 1 or Pennzoil 5W20, 5.5-6.0qts, and good luck trying to prime the filter. Don't worry about priming it because the filter is mounted horizontally and the oil will leak out before you can get it screwed on.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-23-2015, 07:59 AM   #3
Slater2111's Avatar
Oil change!
Every 3000 miles. I have been using Valvoline high mileage synthetic. And a motorcraft filter. But I have been doing a lot of reading and have decided to try Rotella T6. It's hot enough now to use it. It's a 5w-40 full synthetic. I have read that it's a good oil to use for higher mileage engines.
I use 6 quarts and just enough to bring it to the middle of the stick.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 05-23-2015, 08:05 AM   #4
XSlashDashX's Avatar
I go every 5k with mobil 1 ep 5w20 with motorcraft filter and my gf goes 5k with motorcraft 5w20 and motorcraft filter. No problems.
Old 05-23-2015, 10:50 AM   #5
You can prime the filter by filling it about halfway full, and when you spin it on, the oil gets caught in the filter media, and it won't leak out as long as you keep spinning the filter until the gasket seats.
Old 05-23-2015, 11:53 AM   #6
dcm88's Avatar
just did a oil change a hour ago drive 1200 miles a month just to work and back last oil change was idk when couple of months ago with royal purple just tried out pennzoil platinum with pure plus well see if its just as good ... 5w-30 and wix filter
150,000 miles on her
dcm88 is offline   Reply With Quote
Old 05-23-2015, 12:40 PM   #7
Mobil1 ES with Motorcraft filter, change the oil every 7500+ miles. Oil is guaranteed for 15,000 miles between changes.
I use synthetic because its cheaper with longer intervals between changing. It is also an insurance policy in case you happen to over heat somehow. Your protected better.
The green Mustang made it well over 350,000 miles using it.
_____________-------------____________-----------___________---------
**Go to BITOG and you can read lab results on synthetic and conventional oils. May help you make a decision.
_____------_______--------_________-------________--------________------
Other Great Oils:
- Amsoil Signature Series (NOT XL),
-Pennsoil Platinum
-JG Driven
-RedLine
Other great oil filters:
`Mobil1
-K&N
-Pure One
-WIX
LINK TO BITOG- All oil and filter questions with lab results:
Bob Is The Oil Guy | The Internet's Number One Motor Oil Site
Old 05-23-2015, 03:44 PM   #8
Oil change!
I used Pennzoil/Platinum, Mobil 1, and Kendall. They vary from Full Synthetic to conventional oil. Oil weight varies too, depending on where you're at and the climate. Mostly I use Pennzoil, Mobil 1, Wix, and K&N oil filters. But debating on putting Amsoil or Royal Purple in one of my cars.
3,000 on conventional oil
5,000 on synthetic
Adventure till you drop
Old 05-23-2015, 03:59 PM   #9
alecas447's Avatar
Oil change!
Valvoline 5w20 6 quarts every 3000
Synthetic btw
alecas447 is offline   Reply With Quote
Old 05-23-2015, 06:29 PM   #10
TruBluStang03's Avatar
My dad just changed the oil on my car without knowing and he put 10w-40 and he says it's better for the hot summers. Is this bad for my car?
TruBluStang03 is offline   Reply With Quote
Old 05-23-2015, 06:32 PM   #11
No not really. For warmer weather I would do a 5w30, that's what I use. And live in the valley of California.
Old 05-23-2015, 06:37 PM   #12
Will the 10w-40 have any negative effects on the car?
Old 05-23-2015, 07:03 PM   #13
04beautyGT's Avatar
About every 5K miles with 6 quarts of Motorcraft 5W-20 Semi-Synthetic and the Motorcraft filter to go with it. No need to bother priming the filter. Every time I do my oil change my oil isn't even black, its still got the brownish color to it, even when I waited 6K miles, and I've almost got 195K on the odometer.
04beautyGT is offline   Reply With Quote
Old 05-23-2015, 07:29 PM   #14
Slater2111's Avatar
No. You may suffer slightly less MPG. But that's it.
Old 05-23-2015, 07:33 PM   #15
You'll need to let it idle extra long before starting to drive it and drive it extra long before it'll warm up to temp when you can have fun with it.
Old 05-23-2015, 08:59 PM   #16
YES-
Use 5W during summer and 0W in winter. I use 5W year round with my climate.
Old 05-24-2015, 02:50 AM   #17
Steve96's Avatar
5w30 motorcraft and a motorcraft filter for me twice per year. Right before winter storage and right after winter storage to get ready for the summer. Has worked well for me. Turns out to usually be about 4k miles from the spring to the fall, and 0 miles from the fall to spring lol.
1996 GT
Old 05-24-2015, 06:09 PM   #18
Yellastang03's Avatar
Oil life really depends on weather conditions,engine temp,distances, and engine rpm. Milage intervals are only a basic rule of thumb. 3000 is usually the safe bet if you like to beat on your car.
Yellastang03 is offline   Reply With Quote
Old 05-25-2015, 10:13 AM   #19
3,000 miles is overkill with a good filter and a good syn blend like Motorcraft, Super Tech or basic M1. 5-6k miles, check oil level regularly, good filter and a good oil and roll. Never use orange fram death cans. 6 quarts, 5w-30 is OEM spec. 5w-20 was instituted for CAFE reasons. Cap may say 5w-20, that's not what the hood sticker says and not what Ford recommends in the exact same motor everywhere else in the world.
Try adding this to your oil next oil change Joe Dirt 222 General Mustang Discussion 18 05-23-2015 01:04 PM
Smell oil burning thru interior air vents after oil change dentman43 2011-2014 Mustang GT 7 10-27-2014 08:36 AM
First oil change what oil sinister 2011-2014 Mustang GT 48 08-18-2014 07:57 AM
To change or not to change? Djulin 2011-2014 Mustang GT 13 04-03-2013 10:20 AM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
05:50 AM
