Help - Mustang Evolution
Old 05-24-2015, 10:44 AM   #1
mustang_brody's Avatar
Help
Just left autozone b/c my car was throwing a code and came bac that it's running rich and dumping to much fuel wat could b making the car do this
mustang_brody is offline   Reply With Quote
Old 05-24-2015, 10:48 AM   #2
escottcarp's Avatar
Provide the code.
Smoke tires, Not drugs!!
escottcarp is offline   Reply With Quote
Old 05-24-2015, 10:49 AM   #3
What number is the code?
straybullitt is online now   Reply With Quote
Old 05-24-2015, 11:04 AM   #4
They didn't tell me the code they just said it's coming up as it running rich that's it lol
Old 05-24-2015, 01:54 PM   #5
I looked at some stuff on the Internet and they said it could b the maf or my O2 sensor
Old 05-24-2015, 01:56 PM   #6
Yellastang03's Avatar
Help
Go back and find out what the code number was. Knowing what bank is running rich would really narrow down where you have to look
Yellastang03 is offline   Reply With Quote
Old 05-24-2015, 02:38 PM   #7
Ok I'll let u kno in just a min
Old 05-24-2015, 02:52 PM   #8
Old 05-24-2015, 03:00 PM   #9
P0172-bank 1 system rich
P0175-bank 2 system rich
Old 05-24-2015, 04:54 PM   #10
The three most common causes are:
1. Mass Air Flow sensor is dirty or contaminated with air filter oil.
2.Vacuum leak.
3. Fuel pressure or delivery problem.
Old 05-25-2015, 10:26 AM   #11
Pull the MAF element and clean it with MAF cleaner (NOT CARB CLEANER MAF CLEANER), check all vac hoses, and test your O2s with a torch and a multimeter. Multimeters are $7 at Harbor freight and everyone should have a basic propane torch for stuck bolts. Look up the how-tos on google.
Probably a bad O2.
Old 05-25-2015, 10:34 AM   #12
Both of the 02 sensors would have had to fail at the same time, which is unlikely, but not beyond the realms of possibility...
Whatever is causing the codes, is affecting both banks simultaneously. Both the MAF and a vacuum leak are capable of doing that.
Old 05-25-2015, 11:29 AM   #13
I just clean the maf sensor with the maf cleaner and it still has the light on so I'm going to change the O2 sensor next to see if that's it
Old 05-25-2015, 11:31 AM   #14
Did you disconnect the battery for 15 minutes to clear the codes?
Old 05-25-2015, 12:44 PM   #15
I disconnected the battery I'm goin to see if that works
Old 05-25-2015, 01:00 PM   #16
The battery reset thing worked thanks guys
Old 05-25-2015, 05:18 PM   #17
It's always something stupid... Hopefully the issue does not come back.
Sent from my LG-D801 using Mustang Evolution mobile app
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 04:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 06:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
02:18 PM
