02 GT engine choking/sputtering accelerating with load - Mustang Evolution
Old 05-27-2015, 03:49 PM   #1
Recently ive been having an issue with my 02 gt, it idles okay, even revs great with out a load on it, but when im either traveling on the freeway or leaving from a stop if i push down to far on the gas it wants to sputter/choke..it still accelerates, but its like a faint thudding...the shifter wobbles a little and i can feel it in the car..i thought it could be the fuel filter or a vaccuum issue, i replaced some suspicious hoses and replaced the filter but no result, its only when i het into it that it does, also if i hammer down on it to long it smells like burnt emissions or oil..something jot quite sure. I have exhaust turned down right after h-pipe could this be a reason? Any thoughts would be loved. Thanks
CDavis26 is offline   Reply With Quote
Old 05-27-2015, 07:17 PM   #2
I would replace the fuel filter again. Add bottle of Techron into gas tank. Pull Seafoam up through vacuum line into intake manifold slowly.
Double check vacuum lines with carb spray maybe to listen for idle changes.
Replace plugs with copper NGK or Motorcraft. Install FRRP plug wires. Purchase WeaponX ignition coils (Or Motorcraft).
Look for loose bolts, nuts, cold air intake tube connections tight & not leaking air
AIR/FUEL/SPARK Pesky issues pain in A$$.
Update us later.
Edumakate Us Tu.
Old 05-28-2015, 07:48 PM   #3
v8pony's Avatar
CHECK YOUR COIL PACKS, willing to bet thats your problem. My 02 had the exact problem, eventually developed into a constant misfire.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
2002 5spd GT
Feb 2013 Mustang of the Month
Old 05-29-2015, 10:03 PM   #4
Panther140's Avatar
Your miss-firing like hell. That or your ECU just completely gave up the ghost on timing advance. These cars will run with only their ignition module , but it will be at 10 degrees before top dead center, no matter what you do. When the timing is not advancing under load, it will act just like you describe. It will rev without a load just fine, and it will carry a high RPM when you're finally up and moving, but the accelerating part will be so slow and might even have some after-firing (sometimes incorrectly referred to as backfiring)
Panther140 is offline   Reply With Quote
Old 05-30-2015, 06:08 PM   #5
Well the probelm is resolved i replaced all spark plugs with JNKs was easy job just had to buy a spark plug socket that could hold plugs as the came out, id say i got lucky couldve have been much worse like was described above thanks for input everyone hope this helped anyone that needed input with same issue
01 GT 5 Speed hesitation/choking at 40+mph Heffe707 1996-2004 Mustang GT 15 04-06-2014 03:06 PM
car feels like its choking PiojoA7x Pre-2005 V6 Mustang 15 10-11-2013 11:47 AM
Engine popping under load Travis B 1979-1995 Mustang GT 6 07-02-2012 06:30 AM
98 gt (NPI) choking on top end of rpm's leviz79 1996-2004 Mustang GT 14 04-12-2012 08:14 AM
sputtering Stang!! jagger969 1979-1995 Mustang GT 2 04-09-2008 09:02 PM
10:48 PM
