Ignition won't turn - Mustang Evolution
Old 05-27-2015, 04:29 PM   #1
rathke83's Avatar
Region: North Dakota
Ignition won't turn
So I went to the gym today and the car ran just fine. When I came back out to my car to go to work the ignition won't even turn. What could be the problem?
I have a 2002 gt. I tried moving the steering wheel at the same time, nothing. I tried pulling the negative cable for a few minutes to reset the computer, nothing. I don't know what else to do. Please help
rathke83 is offline   Reply With Quote
Old 05-27-2015, 04:49 PM   #2
Jbone007's Avatar
Stick or Auto, if Auto I believe it will lock if it thinks it is not in park also!
Jbone007 is offline   Reply With Quote
Old 05-27-2015, 04:52 PM   #3
rathke83's Avatar
It's a stick
Old 05-27-2015, 05:46 PM   #4
Push down on all of the ignition coil plugs, if no luck, then smack the fuk out of the starter and get in line behind me to replace it.
Got mine for $157.00 OEM Ford.
Old 05-27-2015, 07:33 PM   #5
rathke83's Avatar
Ok I think I figured out its the ignition itself. After googling the crap out of it. How hard is it, and how long could it take to switch that out?
Old 05-28-2015, 05:36 AM   #6
fenixignition's Avatar
ignition wont turn as in physically, the key wont turn? or you turn the key and nothing happens? on a manual, you have the ignition switch, the starter and the clutch pedal position sensor. If that sensor is bad, then the car thinks you arent pushing the clutch in before you start the car.
EDIT: Its called a Starter Safety switch, and its connected to the clutch pedal. i would first check the connection to it. Somehow your foot may have knocked it out. otherwise, check for corrosion. I havent heard of too many of these just dying out like that, but doesnt mean it cant happen.
2002 GT 5sp. 16x,xxx miles
How make fog lights turn on with the ignition Night__Mare 2005-2010 Mustang GT 1 01-13-2015 09:27 AM
Need help 2007 GT won't turn on 2007GT 2005-2010 Mustang GT 7 12-04-2013 02:57 PM
How to Mute Kenwood Nav Voice Prompts / Turn-by-turn Guidance EastTNMustang Mustang Audio & Video 0 11-03-2013 04:25 PM
1995 GT Cam won't turn TheLast5.0 1979-1995 Mustang GT 10 08-29-2012 01:23 PM
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 07:52 PM
03:26 PM
