Breathing sound - Mustang Evolution
Old 05-30-2015, 07:02 AM   #1
Breathing sound
If I run her for a while around town, sometimes when I stop at a light it "breathes" the tach goes up and down between about 650rpm and 1500rpm. I do have a lean code from the O2 sensor before the cats on the drivers side. Checked all fittings on the cai and tightened them down. Bad O2 or bad MAF? Btw its a 2002 gt.
Vinnie02 is offline   Reply With Quote
Old 05-30-2015, 09:23 AM   #2
Panther140's Avatar
Could be that or a possible air leak somwhere
Panther140 is offline   Reply With Quote
Old 05-30-2015, 09:25 AM   #3
Kevin.Cook
Guest
Posts: n/a
You can use soapy water and spray around the headers. See if it bubbles. Have you tried also cleaning the MAF, Throttle Body, and IAC? Since this is an older car, it could be gunked up. Also maybe seafoam the engine. That is always fun
Old 05-30-2015, 04:13 PM   #4
Had the same problem... Check throttle body, could be dirt in form of a thick ring where the flap opens up causing it to stick and as a result, the flap can't open as freely as needed, oh and while your at it clean Iac. Your problems should be gone. I know how that is. When your driving there's no problem then as soon as you stop BAM! Rpm acts up and sometimes the car jukes back and forth when the rpm goes up and down l.
Sent from my SM-N910T using Mustang Evolution mobile app
Treyvon1987 is offline   Reply With Quote
Old 05-30-2015, 04:23 PM   #5
Thanks I will try those suggestions.
Sound and chatter ANC scratch sound from braking Pirate Bman Pre-2005 V6 Mustang 0 06-29-2014 05:04 PM
Please take a moment to thank god you are still breathing. FortyBrandon The Bar 3 10-24-2013 10:29 AM
HELP!!! Whistling sound coming from the front/ engine making a clicking sound. Whitestang23 2005-2010 V6 Mustang 5 07-03-2013 04:36 PM
how (if it could) make my auto sound to a manual sound MaKaVeLi 1996-2004 Mustang GT 18 10-18-2006 09:56 AM
09:35 PM
