Well this is great - Mustang Evolution
Old 05-30-2015, 11:45 AM   #1
alecas447's Avatar
Well this is great
So I come back to a great surprise. I came back from jogging and tried starting my car. It started horrible the first 2 times. Now i try to start it and the theft light starts blinking and it and just makes a tiktikitikik sound I don't think it can be the starter I replaced that not even 8 months ago.
I disconnected the negative terminal so I'm going to wait about half an hour hopefully that fixes.
If not what can this be and what causes this?
alecas447 is offline   Reply With Quote
Old 05-30-2015, 11:49 AM   #2
alecas447's Avatar
Doesn't crank or anything
Old 05-30-2015, 12:02 PM   #3
oxford5pointoh's Avatar
Pats or a dead battery
IG @Oxford5pointoh
Old 05-30-2015, 12:16 PM   #4
alecas447's Avatar
IG @Oxford5pointoh
I'm walking to my local autozone about. 6 blocks I will buy a new battery and hopefully it's that.
What is that pats?
Old 05-30-2015, 12:28 PM   #5
Passive anti theft system. Pretty common they give people grief
IG @Oxford5pointoh
Old 05-30-2015, 12:38 PM   #6
alecas447's Avatar
IG @Oxford5pointoh
How can I fix it?
Old 05-30-2015, 12:53 PM   #7
Well I think your situation is a battery. Since you got the clicking.
IG @Oxford5pointoh
Old 05-30-2015, 01:00 PM   #8
Ubnbit's Avatar
Hopefully just battery and not alternator. Take the old one with you so you can trade the core.
Old 05-30-2015, 02:17 PM   #9
alecas447's Avatar
IG @Oxford5pointoh
The battery was going bad. I replaced it. It's fine for now.
How would I know if it's the pats?
So I don't freak out again lol
Old 05-30-2015, 02:47 PM   #10
Pats would give you nothing when you turn the key (no crank or click) and the security light will come on. Lots of the people who report having the issue have intermittent problems. So it might not start once, come back 5 min later, fired right up.
IG @Oxford5pointoh
---------- Post added at 08:46 PM ---------- Previous post was at 08:46 PM ----------
Glad the battery fixed your issue
IG @Oxford5pointoh
---------- Post added at 08:47 PM ---------- Previous post was at 08:46 PM ----------
Keep an eye on your alternator now. Generally the battery and alternator have issues together. That could be why your old battery dumped on ya
IG @Oxford5pointoh
Old 05-30-2015, 06:50 PM   #11
alecas447's Avatar
IG @Oxford5pointoh
IG @Oxford5pointoh
IG @Oxford5pointoh
The alternator was replaced 5 months ago.
Old 05-30-2015, 06:56 PM   #12
alecas447's Avatar
So was the starter
I replaced them a little after I bought the car
Old 05-31-2015, 10:46 AM   #13
Panther140's Avatar
The PATS situation is funky. There are a few different things PATS can do. When my car threw a PATS code, everything would work except the fuel would get cut off after 2 seconds of running. The igntion and starter would work just fine in my case
Panther140 is offline   Reply With Quote
Old 05-31-2015, 11:07 AM   #14
OP said ::::::::::::::::::::::::::::::::::::Battery replaces OK now !!!!
Old 05-31-2015, 11:12 PM   #15
Steve96's Avatar
My PATs does what panthers did. It will start but shut off after a couple seconds. Im ordering a tune and tuner this week and will have it shut off. It will strand me eventually so i dont drive it unless i dont have to shut it off in case it acts up. Luckily i have been able to get it going again when this has happened by un hooking my battery for about 10min
---------- Post added at 12:12 AM ---------- Previous post was at 12:11 AM ----------
Good to hear it was just the battery
1996 GT
Old 06-01-2015, 03:58 AM   #16
bucko's Avatar
PATS (passive Anti_Theft System) uses a special key transponder chip (located in the ignition keys black top) that transmits its code to a transiever, located by the ignition that the key is inserted into. If the code does not match what is stored in the PATS module, then the ignition is disabled, or disabled right after startup. The LED light (on the dash) will flash differently (as described in your owners manual) to indicate that an attempt was made to start the car with an invalid PATS code for that car.
This is why you simply cannot buy a blank key, have it cut, and expect it to start your car without first having it programmed with your PATS code. If you have TWO keys already, you can do this; if you have only one, then either a dealer or a locksmith will have to do this.
Old 06-01-2015, 04:34 AM   #17
Strange Mud's Avatar
I don't think a tuner can disable PATS....
everyone else pay attention to what Bucko said about extra keys....if you only have two go make a 3rd one (right now!) or if you every loose one it will take a trip to the dealer to make a replacement. you need 2 working keys to make a 3rd.
Old 06-01-2015, 08:53 AM   #18
Slater2111's Avatar
Most good tuners will disable PATS.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 06-01-2015, 10:32 AM   #19
Steve96's Avatar
Most of the tuners can disable it even Bama will.
1996 GT
Old 06-01-2015, 10:35 AM   #20
thx for the learning..........
so why would anyone disable it?
Old 06-01-2015, 10:39 AM   #21
Steve96's Avatar
I didnt know they could until i inquired with them. Im going to get mine disabled because going to the dealer to see what needs to be fixed will cost me as much as a tune for 400 bucks, or at least close. This way i can get a little performance and have the actual programmer for future use also. My key is new, programmed by a locksmith worked for over a year, it could just be my key. I figure at least 200 if i go to a dealer and its just the key, labor, blank, and programming charge. If its more it will cost more as there are several different things that could be wrong and cost even more. Thats why i am going to go this route.
1996 GT
Old 06-01-2015, 12:38 PM   #22
That happened to me. I unhooked the battery for a while then tried again and it worked. Hasn't happened ever again.
Old 06-01-2015, 01:29 PM   #23
rocknbronco's Avatar
To bad to you just turn the ignition to the run position, get a rolling start, and then let off the clutch.
Had a old F150 with a crap starter I refused to replace as it only did it when it was hot, always parked headed downhill and it always started.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 06-02-2015, 03:55 AM   #24
Steve,
that makes sense.
Well well well England, you are turning into the country of the FATTIES Seph The Bar 10 02-28-2007 04:10 PM
Great! Abosolutley Great! Domestic vs Import el cheapo Pre-2005 V6 Mustang 18 07-30-2003 11:16 AM
What a Great morning I had *Rant* Rellik The Bar 6 07-15-2003 07:32 PM
06:06 PM
