Car will not go into any gear. - Mustang Evolution
Old 05-31-2015, 08:27 PM   #1
SkylerTallman_'s Avatar
Hey I bought a 2004 Gt a couple day's ago. The only problem is the car is so difficult to get in all the gears and reverse grinds every single time before it goes in. I can get the car in gear but I'm basically forcing because it takes like 3 seconds every time and I'm putting a lot of effort in it. What could cause that? Would my clutch need adjusting or could it be possible all my syncros are out? I plan on taking it to the shop Tuesday and letting them see what they can do. The clutch is relatively new and I'm not sure if it matters but the clutch is super hard.
SkylerTallman_ is offline   Reply With Quote
Old 05-31-2015, 08:32 PM   #2
Kevin.Cook
Guest
Posts: n/a
Was the flywheel also checked? Can you put the car in gear with the engine off? (Like 1st gear when parking).
Old 05-31-2015, 08:38 PM   #3
I haven't had a chance to get anything checked. Work has me tied up until Tuesday. Yes you can put in gear pretty easily when its off.
Old 05-31-2015, 09:12 PM   #4
Most likely the cable is ****ed. If its every gear its most likely not the trans because if it was then some gears would be fine and others not. Or whoever did the clutch borked it.
Symptoms tell me the clutch is not fully engaging though, probably some SR/Ebay cable in there...
Old 05-31-2015, 09:14 PM   #5
Is there any reason reverse is the only one that grinds for a second. Maybe the reverse syncro is bad?
Old 05-31-2015, 09:21 PM   #6
Put it in 1st prior to reverse and see if it still does it. I usually do 1st, 1st, reverse if I'm having issues. But yes the 5-R slider could be messed up.
Was the car doing this 2 days ago when you bought it?
And do not drive it until you get it looked at. Unless you want to really **** something up.
Old 05-31-2015, 09:24 PM   #7
I will try that and yea it was, I got a little off the price because of the problem. The guy who sold it to me said it just needed the clutch cable adjusted.
Old 05-31-2015, 09:34 PM   #8
Project Pony's Avatar
They always say it's some quick easy fix....
But that's a good place to start. You mentioned the clutch was hard. Does it take an excessive amount of force or is it just heavy?
[SIGPIC][/SIGPIC]
Old 05-31-2015, 09:40 PM   #9
It takes a lot of force lol. I'm like pushing back in the seat to help myself lol. I have the receipt to the clutch that was installed. He gave me a big booklet of paperwork of a lot of the work done. It's in the car though and I'm in bed atm.
Old 05-31-2015, 10:13 PM   #10
Even a heavy aftermarket clutch shouldn't take that much force. Definitely check the clutch cable, but I'd still want to check to see what's going on with the clutch.
[SIGPIC][/SIGPIC]
Old 06-01-2015, 02:29 PM   #11
Most likely the cable is shot. Usually because someone installed an aftermarket cable. Aftermarket cables=no. OEM or MM(OEM) only.
Old 06-01-2015, 11:05 PM   #12
dayves's Avatar
Ya, that's exactly what happened to me last summer and mine was just the cable was all f***** so I had to replace it. I got a whole new kit for around $70-$80 i wanta say. An it only took about 20 minutes to fix.
dayves is offline   Reply With Quote
Old 06-02-2015, 03:48 PM   #13
Panther140's Avatar
My car was doing the exact same thing right after I put a new clutch in. Then I modified my clutch quadrant to pull more cable and it stopped doing that ****. In a perfect world, it should never grind while you are at a stand still. If you push the clutch in, nothing should be spinning at all under power except the engine, flywheel, and pressure plate.
I would bet its 100% your clutch cable. Every symptom you had was identical to mine when my clutch was not able to completely disengage. Get a new cable or get creative with your quadrant
Panther140 is offline   Reply With Quote
Old 06-03-2015, 10:38 AM   #14
akrewson3's Avatar
I also had thought it was a clutch cable, installed it and no luck. Turns out my spec stage 2 clutch plate decided to stick on the flywheel. Has your clutch been slipping at all lately? Just ordered the Exedy mach 400 clutch kit and she'll be ready to go!Click image for larger version
Name:	ImageUploadedByMustang Evolution1433349482.060789.jpg
akrewson3 is offline   Reply With Quote
Old 06-03-2015, 01:07 PM   #15
Panther140's Avatar
Stuck to the flywheel? THat sucks man. what caused it?
Old 06-03-2015, 01:53 PM   #16
What caused it was probably that it was a Spec product...
Old 06-03-2015, 11:01 PM   #17
akrewson3's Avatar
I'm thinking it being a spec product, haven't heard good things about them. Nothing but good reviews on the exedy's from what I've seen
Old 06-03-2015, 11:05 PM   #18
Make sure you install a new flywheel as well. And if you are not an 01+ model which already has an 11" setup, I recommend upgrading to that. Any modular Mustang can use the 11" flywheel/clutch setup.
Old 06-04-2015, 11:05 AM   #19
Panther140's Avatar
I put a Sachs clutch in and it is flawless thus far. If you are looking at cheap clutches, I recommend them
Old 06-04-2015, 01:49 PM   #20
Luk Gold for a budget clutch. $125 on Rockauto and is as good as the oem.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 06-04-2015, 08:08 PM   #21
Panther140's Avatar
^ Ill keep those in mind
« Plasti dip | Fliter »
Transmission not going into 5th gear Jr Sager Pre-2005 V6 Mustang 1 10-19-2014 11:05 AM
Rough Shifting / Not Getting into Gear JoeyM91 2011-2014 V6 Mustang 13 05-23-2014 11:59 AM
HELP PLEASE!!! 2000 Mustang GT won't go into gear with car on!?! WICKED STANG 83 1996-2004 Mustang GT 22 10-18-2012 05:24 PM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
96 4.6 will not go into fifth gear duals 1996-2004 Mustang GT 10 09-05-2008 11:06 PM
06:09 PM
