really hot rims - Mustang Evolution
Old 06-02-2015, 01:35 PM   #1
really hot rims
My front rims are very hot to the touch after a drive and my rear rims are not. once and a while I will hear a grinding.
the car still moves on idle so I don't think the breaks are locked up. any ideas?
also noticed the rotor looks like something is gouging into it maybe?
the holes are fine that stuff is just road grime. and don't mind the black stuff that's just some plastic from the arm of my work safety glasses lol I poked the rotor
Hello is offline   Reply With Quote
Old 06-02-2015, 01:37 PM   #2
natestang07's Avatar
Sounds like you need new brake pafs
Old 06-02-2015, 01:38 PM   #3
I was thinking to take the tire off and check to see what is causing the grinding and to sand down and rough parts on the rotor. is this rotor garbage now or can I save it.
please help
Old 06-02-2015, 01:39 PM   #4
they were just replaced about 4 months ago, could they be done already? I drive to work and home only
Old 06-02-2015, 01:41 PM   #5
Judging by the wear line on the rotors and the grinding I would say they are done. Only way to know is to look
Old 06-02-2015, 01:45 PM   #6
why would the rims be so hot? okay yes I will take the tire off later and take a look at the pads
Old 06-02-2015, 01:50 PM   #7
Could be a stuck piston possibly I suppose
Old 06-02-2015, 02:58 PM   #8
WJL
Most times it a stuck or sticking caliper
WJL is offline   Reply With Quote
Old 06-02-2015, 02:59 PM   #9
But both being stuck at once would be odd
Old 06-02-2015, 04:29 PM   #10
Mile high JDF's Avatar
Looks like your pads are metal on metal and causing the grinding noise. The material in the drilled holes are where the pads got hot and deposited some pad material in there. Unfortunately most shops can't machine drilled rotors so you're basically stuck buying new pads and rotors unless you can find a shop that has the correct machine to resurface drilled rotors. As far as the heat, that means your calipers are sticking. It could be anything from a seized caliper, bad slide pins that are either rusted in or not luricated properly, or even a bad master cylinder or proportioning valve.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-03-2015, 01:30 PM   #11
yup pads are metal on metal only on the drivers side front! all other corners appear fine.
starting to make a pretty rough grinding noise on breaking and turning.
obviously the caliper is seized or sticking like mentioned.
I work every day until Saturday and don't get paid until Friday.
I guess ill need a caliper, rotor and pads for that corner. hope my wheel baring doesn't fry and I loose a wheel or something crazy money money money ..
Old 06-03-2015, 08:13 PM   #12
Panther140's Avatar
You know how your headers/exhaust manifold/Engine are like a foot away from your front wheels? That could also be adding to the heat situation. However, your sunglasses melted when you touched them to your rotor... You need to do a brake job and make sure your lines are not kinked anywhere. You got too much friction going on there and a kinked brake line can cause the piston to stay compressed too long
Panther140 is offline   Reply With Quote
Center Console Really REALLY HOT !!! Black on Boss 2011-2014 Mustang GT 7 08-22-2013 09:28 AM
Hot hot! OutlawGT 2.3 Mustang 7 12-04-2011 10:39 PM
This guy is having a bad day... A really, really bad day JROC The Bar 15 08-16-2007 10:52 PM
well im really really bored right now Zim The Bar 19 01-06-2004 08:30 PM
im really really bored. Zim The Bar 0 11-17-2003 03:59 AM
07:57 PM
