Gas smell 04 GT - Mustang Evolution
Old 06-03-2015, 07:30 AM   #1
XSlashDashX's Avatar
Gas smell 04 GT
What would cause a gas smell from the engine bay? I checked the Rear just in case and no leaks from gas tank. This morning i shift to 5th gear and started to smell gas inside the vehicle for a few seconds and it went away.
Old 06-03-2015, 01:29 PM   #2
Lorraine's driver
ab_mach1's Avatar
If it's smelling like gas in the engine bay, you should check for leaks on the gas lines going to the fuels rails and all around both fuel rails. If there's wetness, touch it with your fingers (when engine is cool) and smell them. If you smell gas, then you'll want to look closer in that area.
Instagram: @ab_mach1
Old 06-04-2015, 02:05 PM   #3
Leak in your fuel line going to the rails or the rails themselves or you have bad o rings on the injectors.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 06-10-2015, 02:20 PM   #4
96NYCGT's Avatar
Send a message via AIM to 96NYCGT
Could be a purge valve
96NYCGT is offline   Reply With Quote
Old 06-10-2015, 06:19 PM   #5
WJL
You want to check the rubber hose that goes from the evap can (passenger side fender well) to the purge valve then to the back of the plenum.
This hose has a tendency to deteriorate and when it does it will smell of gas.
Don't know if this is your problem but it's easy to check
WJL is offline   Reply With Quote
Old 06-11-2015, 07:36 AM   #6
Still on the lookout. Will have to check this weekend. I still get the random misfire at start up after putting new plugs in. I put seafoam in the meantime see if cleans. Also changed my fuel filter.
Low gas mileage, gas leak and smell evan1989 Pre-2005 V6 Mustang 3 03-31-2014 11:08 PM
Gas smell after full tank of gas 93mstnglx 2.3 Mustang 15 02-11-2013 09:37 PM
gas smell in car todd mulder 2005-2010 Mustang GT 13 08-21-2012 07:54 PM
Gas smell at start up/ idle BoLtThEhUsKy 2005-2010 V6 Mustang 6 05-04-2012 10:09 PM
Gas leak/Smell? runvsofthisbull Pre-2005 V6 Mustang 15 12-27-2008 04:58 PM
08:37 AM
