Question - Mustang Evolution
Old 06-03-2015, 01:15 PM   #1
mustang_brody's Avatar
Question
If I buy a 75mm throttle body will I have to buy a bigger new cai or can I use the one I got already
mustang_brody is offline   Reply With Quote
Old 06-03-2015, 01:39 PM   #2
Steve96's Avatar
You can use the one you have
1996 GT
Old 06-03-2015, 02:26 PM   #3
Almost every CAI is 3" (appx 75mm) so you should be fine. Just make sure yours is.
Also, get this one
http://www.summitracing.com/parts/sum-227223/overview/
Its made by Trick Flow, just not TFS branded so you save $40 over the TFS one. Also, being a TFS product means it is USA made vs a chinese knock off from SR/SVE or something grossly overpriced from BBK. And inferior...
Old 06-03-2015, 02:28 PM   #4
Ok thanx and will I see a difference in hp and torque
Old 06-03-2015, 02:37 PM   #5
^See above edit as to the throttle body. You will not see any increase with the stock plenum. For a plenum, get the TFS one from Latemodel.
Trick Flow Mustang Intake Plenum Silver (96-04) 4.6 2V 51800001
Or in black if you prefer that
Trick Flow Mustang Intake Plenum Black (96-04) 4.6 2V 51811001
This is going to be your best bang for the buck/quality setup for a TB/Plenum setup.
Old 06-03-2015, 03:06 PM   #6
Question
Ok thanx and I'm getting it wit the plenum
Old 06-03-2015, 03:19 PM   #7
Yeah 75mm TB and Plenum will give you a little extra. Will make more of an increase when you get a tuner tho.
Old 06-03-2015, 05:15 PM   #8
dwbrand's Avatar
Would a one piece throttle body and plenum be just as good?
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 06-03-2015, 06:52 PM   #9
This means you are talking about the BBK or SR units. No, they aren't as good.
Old 06-03-2015, 07:03 PM   #10
dwbrand's Avatar
Good to know, thanks!
1968 Mercury Cougar
Old 06-03-2015, 07:15 PM   #11
To be blunt... BBK is what ppl who don't know any better put on their cars. Inferior products and they are WAY overpriced.
SR/SVE/Pro Products are rip offs of other companies and sent to china to be made cheaply in most cases. I mean look at the plenums for example. SVE looks just like TFS, SR like Accufab and PP usually rips off Edelbrock's stuff.
Question question!?!? AmericanBulldog Pre-2005 V6 Mustang 11 12-11-2013 08:24 PM
Wheel gap question and lca question Mdazi 2011-2014 Mustang GT 27 05-27-2013 07:11 PM
Wheel Question / possibly stupid question Rogue Slider Mustang Wheels & Tires 8 05-29-2012 12:21 PM
Question: I would like to know from you guys (See background and full question)? dumont75 General Mustang Discussion 16 03-03-2010 06:17 PM
Car question? Duh, of course it's a car question, silly!? imported_daman General Car Discussion 3 08-17-2009 06:40 PM
01:44 PM
