2003 Mustang Brake Caliper Help - Replace or Sell? - Mustang Evolution
Old 06-05-2015, 11:41 PM   #1
Exclamation 2003 Mustang Brake Caliper Help - Replace or Sell?
Hey guys. This is my first post here, and I really need y'alls help. I have a 2003 Mustang Convertible (non-GT), and I took it in for a tire rotation and 100k flush last week. However, when I picked her up from the lot, there was a weird grinding sound around my front left tire. I brought her back, and the mechanic is saying it's a locked caliper issue with the front driver tire, and it's affecting both the brake and the suspension. He says I need a new brake, a new suspension, and a new caliper, and is requesting 3k to fix ($500 more than the car's even worth). I think they screwed something up because she wasn't having any issues before I brought her in for maintenance, but they provided a tire rotation and 100k flush, and now it's grinding anytime I brake or decelerate at less than 30 mph.
I love this car, and I'd rather not part with it, but I want to know if what the mechanic's saying is reasonable, or if I should sell her and move on. Any help would be appreciated. Thanks y'all!
kshed is offline   Reply With Quote
Old 06-06-2015, 12:36 AM   #2
Mile high JDF's Avatar
Yeah you're getting screwed. For one a locked up brake will not cause the suspension to go out. Take it to a real mechanic and get an honest opinion on it. Does it pull when braking or when or driving straight? What all was included in this 100k service?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-06-2015, 07:02 AM   #3
Guessed So
Yeah, my usual mechanic is on vacation so I brought it to this other guy hoping isn't wasn't something major.
It actually doesn't pull at all. In fact, the drivability of the car isn't really impacted other than having to push slightly harder on the brakes. The noise is the biggest issue.
The 100k service involved a system flush, oil change, tire rotation, new fluids (though I guess not brake), and a 21 point inspection.
Old 06-06-2015, 08:06 AM   #4
jeno's Avatar
Yeah there screwing you have you flushed the brake system if not do that first then see if it drags then had a issue with my daughters nitro they said the system was contaminated so the nitro needed the entire brake system replaced I called bs flushed refilled billed the system and all is good now
Sent from my Nexus 6 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 06-06-2015, 08:57 AM   #5
Slater2111's Avatar
Man if they are trying to screw you like that. I'd check all the fluids they said they exchanged. Make sure they really exchanged them. Also that caliper is something you can fix yourself.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 06-06-2015, 09:21 AM   #6
Steve96's Avatar
Ridiculous shops like this should be shut down.
1996 GT
Old 06-06-2015, 09:44 AM   #7
H.Doofenshmirtz's Avatar
Region: Australia
Something like that might be worth a call/letter to the BBB, cuz that really sounds like a load of bull
No work and no pony makes Doof a dull boy...
H.Doofenshmirtz is offline   Reply With Quote
Old 06-06-2015, 09:52 AM   #8
jeno's Avatar
Exactly well put
Old 06-06-2015, 12:32 PM   #9
wild. Exact same thing is happening to me hah.
take a look at your rotor on the side that it is grinding! you will notice it is getting destroyed. and although the driveability seems fine and the grinding is the annoyance. if your caliper is stuck all your doing is forcing that tire to spin when driving and burning up your wheelbaring/hub assembly. witch will be noticed during the brake change once the rotor is off.. more $ . and if you wait long enough your wheel may fall off.
Hello is offline   Reply With Quote
Old 06-06-2015, 12:38 PM   #10
jeno's Avatar
He's correct you shouldn't be driving it in this condition save your wheel bearing if it isn't already bad from the extremely heat
Old 06-06-2015, 12:45 PM   #11
I am still driving mine hah I just try and down shift and not use the brakes unless I need to on my way to work and back home. so not as much grinding haha I replaced the wheel baring with a cheap one in the past so in a week or two I will justify two new wheel barings oem cobra calipers and brackets ss hoses and rotors and pads. going to be expensive so I understand the op's question if he should sell or fix. I say justify the mod
Old 06-08-2015, 12:24 PM   #12
Damn man buy the parts yourself and pay someone to do them on the side. Pretty much any "weekend mechanic" with a set of basic tools can do brakes.
I'd just get everything from Rockauto. New calipers on both sides, Raybestos rotors, Centric Posi Quiet ceramic pads and then DIY or have a friend do it or wait for your mechanic to come back.
Do not drive it as has been said. Tons of heat building up which could cause all sorts of problems.
And no... $3k? Lolwtf, I would ask him straight to his face if that includes the asslube or if that is going to be tacked onto the price and then walk out the door. Like.... $3k for brakes... you could buy an entire upgraded aftermarket 4 piston race setup installed for that price... Installed...
2003 mustang
Brake Caliper help!!! Son_of_Zeus 2011-2014 V6 Mustang 4 07-07-2013 10:44 PM
brake caliper paint question bluestang1724 Pre-2005 V6 Mustang 11 03-23-2011 11:53 AM
im about to replace my clutch/flywheel what else should i replace? 1996v6stang Pre-2005 V6 Mustang 2 07-12-2010 11:22 AM
Rear brake caliper anchor bolt size/help CakeOrDeath? Pre-2005 V6 Mustang 5 09-01-2007 12:04 AM
Brake Caliper Paint? FloMasta24 Mustang Audio & Video 21 09-12-2004 04:06 PM
10:46 AM
