Driver side window 2002 mustang gt - Mustang Evolution
Old 06-06-2015, 10:53 AM   #1
Noah7373's Avatar
Hey everyone I was wondering what is wrong with my driver side window. I rolled it all the way down like I have been normally doing and it won't go back up. The passenger side will roll up but not the drivers side. I just used GUNK engine degreaser to clean my rngine. I don't know if that has anything to do with it. By the way never use that stuff it's horrible and it didn't do anything. And also I can hear a fuse clicking by the pedals when I try to roll up the window.
Sent from my SM-G900R4 using Mustang Evolution mobile app
Noah7373 is offline   Reply With Quote
Old 06-06-2015, 11:11 AM   #2
Noah7373's Avatar
Nevermind I got it fixed. I slammed the door while holding up on the button. Is there any way to keep this from happening though? Both my windows squeak when they roll up! Any suggestions?
Old 06-06-2015, 11:23 AM   #3
The lift motor for the window probably needs to be replaced. I think that some guys have found that they can avoid getting the window stuck by not rolling it down completely.
Old 06-06-2015, 11:58 AM   #4
Noah7373's Avatar
Okay I will check on my motor if I have another problem! Thankyou!
Old 06-06-2015, 12:33 PM   #5
Slater2111's Avatar
I've had that interment problem also. Sometimes it doesn't like to roll down but it always comes up. When I slam the door it works. I can't imagine what it could be.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 06-09-2015, 01:33 AM   #6
alecas447's Avatar
My drivers window is really slow when rolling it up specially if I do both at the same. Mines likes to squeak too but that comes and goes
alecas447 is offline   Reply With Quote
Old 06-09-2015, 01:35 AM   #7
Window motor or regulator is going bad. It's very common in these cars. Happened to mine and I fixed it the same way you did. Then a week later it went out for good. Swapped the motor and it's been rolling up and down faster than ever.
Old 06-09-2015, 01:37 AM   #8
alecas447's Avatar
How hard is it for DIY?
Old 06-10-2015, 06:12 PM   #9
WJL
it's Pretty easy, there is a you tube video on how to take the door cover off you will need to drill out the rivets holding the window glass in.
there might be a window replacement video too, you will have to check
WJL is offline   Reply With Quote
Old 06-10-2015, 06:25 PM   #10
jeno's Avatar
Shouldn't be hard you will need a rivet gun to install new motor
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 06-10-2015, 07:06 PM   #11
WJL
I used bolts with nyloc nuts instead of rivets just make sure they are not to long
Old 06-10-2015, 08:07 PM   #12
jeno's Avatar
You have no issues with them coming loose with vibrations
Old 06-11-2015, 03:23 PM   #13
WJL
That's why i used the nylocs, they have a nylon tip that prevents the nut from backing off due to vibration.
They have been in my car for over a year with no issues.
Old 06-12-2015, 08:20 AM   #14
jeno's Avatar
Good to know thanks for that info
Sent from my C6916 using Tapatalk
2002 mustang
Driver Side Window won't roll down a3705872 Mustang Audio & Video 16 07-05-2015 10:12 AM
Driver side window JCOB72 1996-2004 Mustang GT 3 02-28-2013 07:31 PM
Daily driver :: 2002 ford mustang KY02MUSTANG Member Garages 0 01-06-2012 08:49 AM
Driver side window help needed buck199 2005-2010 Mustang GT 1 07-16-2011 08:48 PM
driver side window motor / switch ? Dark02Pony Pre-2005 V6 Mustang 2 06-21-2005 10:02 PM
05:02 PM
