help - Mustang Evolution
Old 06-06-2015, 03:18 PM   #1
help
Hey guys I did a V8 swap on my 97 mustang after switching ecu it will no longer start will simply reprogramming the v6 key I have work or I have also heard bcm needs changed as well?
hudsonb83 is offline   Reply With Quote
Old 06-06-2015, 03:29 PM   #2
jeno's Avatar
not sure but since you changed the ecu pats is probably stopping you probably a reprogram for the key
jeno is offline   Reply With Quote
Old 06-06-2015, 08:38 PM   #3
If this is truly a PATS issue, I believe that you have two options.
1. A trip to your local Ford dealership for a re-flash.
2. A tuner that has the capability to disable the PATS system.
Old 06-07-2015, 12:35 AM   #4
Steve96's Avatar
A tuner to disable will probably be the most cost effective plus then you have a tuner!
1996 GT
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 04:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 06:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
03:40 AM
