Car squeaking/squealing - Mustang Evolution
Old 06-09-2015, 08:48 AM   #1
bkh1994's Avatar
So my car just started squeaking today. It's not brakes because it does it when just idling. You can hear it when the car is running, driving. Could it be the serpentine belt? I know it needs to be changed out and I already have one, I just haven't gotten around to changing it. It sounds sort of like those old minivans that you hear going down the road sort of squealing. I know what the power steering pump sounds like, it's not it I don't think. Thanks
bkh1994 is offline   Reply With Quote
Old 06-09-2015, 09:25 AM   #2
Project Pony's Avatar
Since you already have the belt, switch it out. Takes less than 5 minutes and you'll know right away if that is the culprit
Sent from my SM-G920T using Mustang Evolution mobile app
[SIGPIC][/SIGPIC]
Old 06-09-2015, 01:10 PM   #3
My Car recently started squeaking and groaning as the front suspension moved. I have sprayed silicone on all the bushings and so far no luck. Anyone else have this issue?
timbob is offline   Reply With Quote
Old 06-09-2015, 01:17 PM   #4
XSlashDashX's Avatar
Could be balljoints.
Old 06-09-2015, 09:59 PM   #5
Steve96's Avatar
Probably ball joints. Mine did this before i had to replace mine.
1996 GT
Old 06-10-2015, 05:44 AM   #6
Its the belt or the idler/tensioner. I'd replace everything honestly if the car is older. At higher miles the bearings in the pullies just wear out and they aren't expensive on Rockauto or Amazon.
For the person who does it when the car is moving, probably balljoints.
Old 06-10-2015, 12:36 PM   #7
bkh1994's Avatar
I got the belt swapped out and no squeak anymore. Thanks!
Sent from my SPH-L710 using Mustang Evolution mobile app
Old 06-10-2015, 11:05 PM   #8
Steve96's Avatar
Good to hear that your issue is fixed. The other member with the squeaking from suspension could be ball joints. I lubed mine with silicone thru the boot etc this worked for a couple weeks but didnt go away until they were changed.
1996 GT
Need with squealing in the rear end of car BeastGT 2011-2014 Mustang GT 3 09-03-2014 08:36 PM
Brake squealing!! austinknoll Pre-2005 V6 Mustang 12 12-05-2012 10:52 PM
Metal squealing noise after driving for a while Patches89 1979-1995 Mustang GT 11 08-20-2012 06:09 PM
squealing noise 98mustang11 Pre-2005 V6 Mustang 14 04-17-2012 04:21 PM
My car is squealing, I dont think the belt needs to be replaced? bernardas General Mustang Discussion 3 03-02-2010 03:39 AM
06:55 PM
