Not wanting to start at first?? - Mustang Evolution
Old 06-09-2015, 12:05 PM   #1
dayves's Avatar
Everytime I start my car it idles high for about 5 seconds then drops until it dies. It didn't before but it was seldom and now it's every time I start it. I have 0 idea what it could be, the only thing I thought of was fuel pump maybe?? Any help would be appreciated. Thanks
dayves is offline   Reply With Quote
Old 06-09-2015, 12:35 PM   #2
dayves's Avatar
Little update, was driving home and some tractor was going real slow so I was behind him and some other cars, I was in 3rd, downshifted to second then went. I went to fourth, passed em then went to slow down and realized my car shut off, I wasn't even close to red lining or anything. Never had this happen. Not sure if that has something to do with what has been happening when I start it or what.
Old 06-09-2015, 02:33 PM   #3
Junior Member
Region: Arkansas
I had the same exact issue with mine. Ended up having to replace the fuel pump unfortunately
Sent from my SCH-I545 using Tapatalk
jcfan4u is offline   Reply With Quote
Old 06-09-2015, 02:34 PM   #4
dayves's Avatar
Damn, that's what I was hoping I wouldn't have to do. How much did it end up costing?? And how long until it went out??
Old 06-09-2015, 02:36 PM   #5
Junior Member
Region: Arkansas
For me it cost about 150 for the part and labor but I guess that differs on Where you go/ buy it from. it would run for about 30 seconds when idling then die suddenly
Old 06-09-2015, 02:40 PM   #6
dayves's Avatar
Should I upgrade and get a bigger fuel pump with more liters per hour or should I just stick with stock lph?? I wanta upgrade my injectors in the near future as well.
Old 06-09-2015, 02:41 PM   #7
Junior Member
Region: Arkansas
Me personally I'm new to mustangs so i would have no clue I just stuck with the stock pump
Old 06-09-2015, 02:42 PM   #8
dayves's Avatar
Hopefully someone reads this and can tell me 😁
Old 06-09-2015, 02:43 PM   #9
Junior Member
Region: Arkansas
Best of luck to you haha maybe you'll get lucky and it won't be the pump
Old 06-09-2015, 02:48 PM   #10
dayves's Avatar
And will I just need the fuel pump or the fuel pump assembly??
Old 06-09-2015, 02:50 PM   #11
Junior Member
Region: Arkansas
I just needed the pump fortuently
Old 06-09-2015, 05:29 PM   #12
keeney35's Avatar
The pumps are pretty easy to change but while your in there I would upgrade.. The bbk on American muscle is a good one
keeney35 is offline   Reply With Quote
Old 06-09-2015, 05:32 PM   #13
I wouldn't trust a bbk pump as far as I could throw it. What year car is this for first thing. Second thing, to actually get a pressure gauge and check your pressure before you just go randomly swapping out parts.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 06-09-2015, 06:07 PM   #14
dayves's Avatar
It's an 02 GT, not sure if bolt-ons matter when choosing what lph but I have an off road H-pipe, flow masters exhaust, trick flow throttle body, K&N cold air and long tube headers. I've never looked into fuel pumps so I truly have no idea what to get or what size
Old 06-09-2015, 06:09 PM   #15
You need to get a gauge on the rail and make sure it's actually the pump first. Hell it could be as simple as a clogged fuel filter.
Old 06-09-2015, 06:10 PM   #16
dayves's Avatar
I think my dad has the gauge I need, if so im gonna do it now and check. Where should my psi be for it to be good?? And does the car need to be on or just key turned??
Old 06-09-2015, 07:16 PM   #17
dayves's Avatar
So I don't have the gauge I need, is there any other way to test if it's going bad. Would it throw any codes on my tuner??
Old 06-09-2015, 07:24 PM   #18
Slater2111's Avatar
Do you have a cheap gas station bicycle tire pressure gauge? If you do it can be done with that.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 06-09-2015, 07:34 PM   #19
dayves's Avatar
Nope, wish I did 😒
Old 06-09-2015, 07:38 PM   #20
dayves's Avatar
And not sure if it rules anything out or not, but when I started up to move it it almost died but as long as I gave it a little gas (with the pedal), it didn't die then continued to idle??
Old 06-09-2015, 07:58 PM   #21
Simple stuff first. Change your fuel filter. If its original, it may be very clogged and its routine maintenance you should be doing anyway.
Old 06-09-2015, 07:59 PM   #22
Slater2111's Avatar
Hmm. Look at your vacuum lines going to the plenum. Also clean your MAF. It sounds like it's getting fuel and spark. Check to see if there are any leaks going to the plenum or any in general. I forgot to simply tighten a vacuum line going to my plenum and it would not start and idle for anything.
Old 06-09-2015, 09:06 PM   #23
dayves's Avatar
Fuel filter was changed when I got it almost 2 years ago, should I still change it?? An okay thanks, I'll check those tomorrow!
Old 06-09-2015, 09:07 PM   #24
Yes you should and unless you did it yourself are you SURE they actually changed it?
Old 06-09-2015, 10:12 PM   #25
dayves's Avatar
Ya, changed it myself
Old 06-10-2015, 05:35 AM   #26
Ah ok.
You can buy a basic fuel pressure gauge kit anywhere. Screws to the port in the rail and should have a bleeder hose on it too. I've got one I got like 10 years ago for $25 at one of the box stores on the shelf that I use every now and then. Good news for me is the car I just got has a gauge right on the pillar so no having to **** with it this time. Its a good tool for anyone to have though, for any vehicle.
Old 06-10-2015, 06:07 AM   #27
dayves's Avatar
Ya, I need one just to have one
Wanting to be happy with Lund tune, but not MOOSEDAWG29 2011-2014 Mustang GT 40 05-10-2015 10:53 AM
Car would not start-could not be jumped-then started richardcrowson1 Pre-2005 V6 Mustang 8 06-02-2010 08:25 PM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
Car will not start on first try? imported_kit 1996-2004 Mustang GT 4 08-18-2009 04:36 PM
1990 mustang 5.0 not wanting to run Big Pete 1979-1995 Mustang GT 6 02-01-2009 09:15 AM
04:54 AM
