Gains from heads and stage 1 cams - Mustang Evolution
Old 06-12-2015, 01:41 PM   #1
LaserRed99's Avatar
Looking to get some upgrade work done on my '99 GT, and have been debating between a Vortech V3 or just some Trickflow heads and a stage 1 cam. Obviously I'd get more power going with the blower, but there's also the cost factor and the fact that it's harder on the car. I've been quoted about $7000 for all the parts, labor, and the tune. Haven't asked for a quote on heads/cam yet, but I assume it should be several thousand cheaper.
Do you think I'd be able to hit 300 wheel horsepower with the following mods and a good dyno tune? The engine is in great shape. Ford remanufacted with about 16k miles on it now.
Already existing mods:
- JLT in-fender cold air intake
- MAC longtube headers
- catted X-pipe
- Borla Stingers catback
Want to add:
- Trickflow Twisted Wedge heads
- Stage 1 cams (should I go with Comp Cams?)
I'd love to hear final power numbers from people who have done a similar setup on their 99-04 GTs! Do I need to upgrade my injectors?
'03 Mach 1 5spd
Fully forged Manley rods/pistons, Cobra crank, ARP hardware, 8.5:1, Procharger P1SC w/ intercooler, AFM power pipe, 60# injectors, 03/04 Cobra tank with dual fuel pumps, Kenne Bell Boost-a-Pump, O/R X pipe and Flowmasters, Exedy stage 3 clutch, Steeda Tri-Ax, Front and rear upper + lower control arms, Ford Racing springs, Bob Monks tune 448 rwhp @ 9 PSI
LaserRed99 is offline   Reply With Quote
Old 06-12-2015, 05:56 PM   #2
You'll want at least 24s for injectors. TFS heads with cams on the 281 will get you over 300 no problem.
I wouldn't do it personally, you can get close to 300 with just cams on PI heads and run low 12s.
Old 06-13-2015, 05:29 AM   #3
thyreaper's Avatar
Ya dont do the heads listen to scotty, because ur going to hit a wall being n.a and when u want more u will have to either go juiced or blown in which u can do that with stock heads a d make wayyy more power then n.a... Now there are places that will port ur stock heads alot cheaper then buying trickflows which will net u decent n.a numbers being na and while the heads are off u can get u some valves with the lips cut (mhs has them cheap) so u can run a bigger cam and u can also notch the pistons those 2 combined u will not run into ptv issues
thyreaper is offline   Reply With Quote
Old 06-13-2015, 04:34 PM   #4
TFS heads are basically for ppl running a max effort NA motor or they want to go over 700hp on a boosted application. Ported PI heads flow well... like... REALLY well. And they much cheaper. At least around here there is a badass head porter who does full PI ports for $1500 and you can sell him your cores to make it even cheaper. Even if you have to go with MHS and pay the shipping it is still a damn good deal.
Porting and polishing heads. How much? And what gains? Luna1994 General Mustang Discussion 3 11-29-2013 09:33 AM
Thinking about MHS NPI stage 1or 2 cams for my NPI heads. leviz79 1996-2004 Mustang GT 1 09-12-2012 12:58 AM
which cams show bigger gains? 07regency 2005-2010 Mustang GT 5 07-14-2012 12:59 AM
stage 2 patriot performance heads an cams o3mustangGTafs 1996-2004 Mustang GT 3 09-06-2006 05:42 PM
stage 1 v6 = what gains? tedness Pre-2005 V6 Mustang 18 02-03-2005 07:46 PM
12:14 PM
