Strange noise - Mustang Evolution
Old 06-13-2015, 02:30 PM   #1
mustangmar2001's Avatar
Strange noise
I'm trying to figure out what is causing the noise. Seems like when I hold force against the dash, the noise would go away. When the air conditioner is on, the noise get worse sometimes. Has anybody had this problem before? I attached a video!
mustangmar2001 is offline   Reply With Quote
Old 06-13-2015, 08:16 PM   #2
I sure have! And here is how I fixed it!
Oh, by the way, if any of you guys have a book of matches that is Dark Charcoal colored, I sure would appreciate it if you sent them to me so that they will match my interior!
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 06-13-2015, 08:19 PM   #3
Lol creative. Thanks
Old 06-13-2015, 08:29 PM   #4
Lol.
Some of the little vent doors had come loose and were rattling. I finally fixed them but now the whole assembly rattles, like yours.
I'm going to remove the vent and put some small pieces of self-adhesive weatherstripping behind it and see if that helps to insulate it from rattling against the dashboard. I'm going to do the same thing to the shifter bezel because it also rattles.
Old 06-13-2015, 09:15 PM   #5
bkh1994's Avatar
If it's anything like mine, my vents started warping. So I took some fishing line and tied it tight to hold it in the right shape, no more rattle and the vent flaps still work
Sent from my SPH-L710 using Mustang Evolution mobile app
bkh1994 is offline   Reply With Quote
Old 06-13-2015, 09:22 PM   #6
Ubnbit's Avatar
I'd love to see some pics of that 98 cobra. I had a 97. Miss that car bad lol. Also from Kentucky but live in Tennessee.
Old 06-13-2015, 09:38 PM   #7
Ubnbit's Avatar
http://www.americanmuscle.com/ford-a...ezel-0104.html
Is this the part rattling? Expensive little guy. I had a folded up piece of cardboard aiming my passenger side light lol. It worked perfectly.
Old 06-14-2015, 05:30 AM   #8
Yes! I'd figure it was something major causing the rattling but I guess it's nothing to worry about. I'll do the cardboard trick to help with that. Would replacing the radio bezel in the near future help?
Old 06-14-2015, 06:27 AM   #9
Ubnbit's Avatar
If there is nothing wrong with it, I wouldn't replace it. I would do what stray said up there. It probably needs some kind of buffer to help it. You can pick up that weather stripping at Walmart.
Old 06-14-2015, 10:27 AM   #10
fenixignition's Avatar
i used that 3m trim tape, usually meant for taping crappy chrom trim pieces to your exterior. (Such as those awesome looking fender vents you can put on your chrysler 200)
but i just lined it up inside and that gave it something to sit on, and stop rattling finally.
2002 GT 5sp. 16x,xxx miles
Old 06-14-2015, 08:54 PM   #11
Just pull that bezel and see if anything is loose or rattling. Re-install with some sort of padding like some sticky foam or whatever.
Old 06-15-2015, 10:49 AM   #12
dwbrand's Avatar
My fiancée used to shove gum wrappers in it to make it stop. I haven't done anything to it, but it hasn't rattled in a long time.
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Strange sound at engine startup? 3.7 also a steering noise. alludc 2011-2014 V6 Mustang 12 08-13-2012 08:48 AM
Strange noise Ryan7racin 1996-2004 Mustang GT 12 04-15-2012 06:24 PM
strange clutch noise R1CK3R Pre-2005 V6 Mustang 10 10-02-2009 10:47 PM
Strange Noise HELP 19ClearCobra96 1996-2004 Mustang GT 10 09-26-2005 01:29 AM
Strange noise....fuel pump? Ghostbuster Pre-2005 V6 Mustang 12 06-17-2005 11:01 AM
12:27 AM
