Losing power on turns and take offs car sputters when at or below 1/4 tank - Mustang Evolution
Old 06-15-2015, 12:57 AM   #1
Exclamation Losing power on turns and take offs car sputters when at or below 1/4 tank
My mustang its a 4.6 gt loses power when turning or on take offs from a stop or a light it only does it when at or below 1/4 tank and anything fuller it does it when floored it feels like it slightly loses power if it's below 2000 rpms in any gear every few seconds I did 3 fuel injector cleaners and used premium fuel when I would put the injector cleaner it would go away but not I have a Check engine light its a P0306 misfire cylinder 6 and I did one more fuel injector cleaner and a tune up with new ignition coils and a 3 step filled with premium gas the check engine light went away for about a week before it felt like it would lose power again then It came on my car would used to take corners even with the needle below 1/4 tank and never hesitate but now even a corner at 20 mph if I floor it the car stays at the same rpm doesn accelerate or decelerate just cruises if I let of the gas and press it slowly it will rev up slowly I don't know when else to really do I want to check my compression for the misfire, the fuel injectors for her loss of power when below 2000 rpms and the fuel pressure to make sure it's not the fuel pump that maybe clogged or can't deliver the fuel as needed I also replaced the fuel filter what do I check or do?
DJ4LIF3 is offline   Reply With Quote
Old 06-15-2015, 01:55 AM   #2
GHO5T5NIPER's Avatar
Change Spark plugs yet? Fuel pump could be going bad too
GHO5T5NIPER is offline   Reply With Quote
Old 06-15-2015, 11:04 AM   #3
Do the fuel pressure test first. It's the easiest to do.
Old 06-15-2015, 11:13 AM   #4
I changed the spark plugs to iridium spark plugs when I did the tune up
Old 06-15-2015, 11:14 AM   #5
I'll do the pressure test today
Installed new Airaid CAI and Bama tuner race mode and now car kind of sputters when a mharmon671 2011-2014 Mustang GT 15 10-30-2014 11:09 AM
Car Sputters In Reverse jleber123 Pre-2005 V6 Mustang 28 07-23-2013 03:55 PM
I washed my engine, now it stumbles and sputters? Mike90 1979-1995 Mustang GT 23 01-20-2013 01:31 PM
2010 Gt 4.6L with JLT, SCT Tune, and BBK throttle losing power yoshywown7 2011-2014 Mustang GT 3 06-10-2011 11:51 PM
No power below 3k jjpea 1996-2004 Mustang GT 7 06-11-2008 10:21 AM
03:45 AM
