Rearend whine very loud. - Mustang Evolution
Old 06-15-2015, 02:19 AM   #1
Speed_Mister's Avatar
Region: Arkansas
My rearend whine is loud on and off throttle. The rearend has a f150 diff and moser 31 axles. The rearend has 50,000 miles on it. It's launched on radials and slick at 6k Rpms and it still rolls. If I added heavier weight lub oil and friction lub should I be okay? I hear clunking noise but only when I turn sharp slowly and I'm thinking its a blown out control arm bushing besides I do have uneven wear on my tires. Let me know I need to get my rearend in shape to take it to the strip again.
2004 Mustang GT 5 Speed Full Bolt On 370rwhp 440rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 06-15-2015, 12:44 PM   #2
I'm not exactly sure what your question is, but using a heavier weight gear oil might quiet your rear end down a bit. It won't, however, guarantee that you will not break something while doing 6 grand launches on slicks.
Old 06-15-2015, 12:56 PM   #3
Kevin.Cook
Guest
Posts: n/a
Any idea what gear ratio you are sitting at right now? Sometimes shorter gear ratios (3.73 or 4.10), have a tendency to be noisy sometimes. Ford Friction Modifier will sometimes help a little with the noise. However, if the noise is on the pinion bearing's side, Friction Modifier won't do anything. This is assuming the whining is coming from the gears, you could always take it in to get inspected.
Old 06-15-2015, 02:27 PM   #4
Region: Arkansas
I have 4.10 gears. And it's really loud my friend said he could hear the whining outside the car on the interstate.
---------- Post added at 03:26 PM ---------- Previous post was at 03:25 PM ----------
Might need to get it inspected. I was just wondering what all could hear noise damage.
---------- Post added at 03:27 PM ---------- Previous post was at 03:26 PM ----------
Full Bolt Ons
370rwhp 470rwtq
Old 06-15-2015, 04:56 PM   #5
Kevin.Cook
Guest
Posts: n/a
If the noise is coming from the differential, then they will need to isolate what is bad, if anything. Sometimes i could be a failed pinion bearing, low on differential fluid, etc.
Old 06-15-2015, 09:13 PM   #6
alecas447's Avatar
Mine has been whining since I bought it. Stock gears
alecas447 is offline   Reply With Quote
Old 06-15-2015, 10:17 PM   #7
Region: Arkansas
Probably low on diff oil but after I got it build it had almost no whine but after the years of the spirited driving its whining hella hard. Check the axles and they aren't bent. Hopefully the spindles on the moser 31 splined axles are okay though. And I'm hoping my diff is okay I'm hoping it's just the ring or pinion gears and bearings. Maybe it's just time to freshen up them bearing and final gears.
Full Bolt Ons
370rwhp 470rwtq
Old 06-15-2015, 10:25 PM   #8
If it is making a lot of noise, where it wasn't before, there is definitely something wrong. As far as your question about what could be damaged, you really need to disassemble the rear end to know exactly.
Old 06-17-2015, 05:19 PM   #9
EggOfNogg's Avatar
Probably just needs a new bearing kit. And when you in there check over both axle from top to bottom
1991 lx 5.0 mustang x2
EggOfNogg is offline   Reply With Quote
loud whine twodie4 Pre-2005 V6 Mustang 7 04-24-2013 04:06 PM
BUSTED! very very very slight WW Tbird232ci The Bar 6 12-18-2005 01:54 AM
Very Very clever! Ken The Bar 4 05-14-2004 05:40 PM
So there I was....... (very very long) Ken The Bar 19 10-15-2003 04:47 AM
07:14 PM
