Supercharger and cams! - Mustang Evolution
Old 06-15-2015, 02:33 PM   #1
Ahmed ali khan's Avatar
Hello everyone
I was thinking of adding a supercharger on my fully bolton cammed GT. It has comp cammed stage 2 xtream energy
And i want to keep it on stockblock
And car has UDP also but il remove them soon and put back the original ones
I can go with vortech V3 7-9psi kit
Or kenne bell 6psi intercooled
With john lund tune
Ahmed ali khan is offline   Reply With Quote
Old 06-15-2015, 05:59 PM   #2
Either one should work good.
Just keep the tune below 450 hp and the engine should be fine.
Old 06-15-2015, 06:24 PM   #3
I'd say more like 425 to the wheels. That's what I'm going to be tuning my replacement motor too. If I ever get started anyway...
I'll also recommend the Paxton.
1999-2004 4.6L Mustang GT Supercharger Systems | Paxton Superchargers
Its a better "starter" kit than the S trim is as you won't need to upgrade the headunit if you ever do a built engine. The Novi 2000 moves a LOT of air.
Old 06-15-2015, 06:36 PM   #4
Rapinator126's Avatar
Spray it.
Old 06-15-2015, 07:39 PM   #5
What are your goals for the car?
Old 06-15-2015, 08:19 PM   #6
Nope.
450
I want to see Ahmed at the top of his game!
Life is too short to be rolling around with only 425 hp. You can always buy a new engine but you can't buy back those days that you were driving around with only 425...
Old 06-16-2015, 04:29 AM   #7
Ok and these cams xtreme energy they will work fine with charger right?
And yeah my goal is 400rwhp for now
With cams the car should do 400whp on low boost
Old 06-16-2015, 06:23 AM   #8
Originally Posted by straybullitt View Post
Nope.
450
Lol. **** it just crank it to 550 and see how long she holds.
Stock cams. You don't need anything besides those with a supercharger to get you to 400. Save your money for the supercharger.
Old 06-16-2015, 02:40 PM   #9
They aren't optimal for FI but since you already own them and they are already installed, they should work fine.
Old 06-16-2015, 02:58 PM   #10
Both you and Scotty are considering going with a remote tune. I don't know a lot about the process but, from what I have gathered, the tuner sends an initial tune and then you install it, drive the car, and then send them back a data log from which they "fine tune" the tune. I'm guessing that after you go through the data logging process a few times, the tune is considered acceptable and everyone is happy.
My question is, then what happens?
Do you take the car and put it on a dyno to see what the horsepower number is?
What if you got a really good tune and you are at say 455 hp?
Would you ask the tuner if he could turn it down a bit?
Old 06-16-2015, 03:54 PM   #11
If I had a really good tuner say it was spot on and safe at 5800 I'd roll with it.
Yes the process you described is how it works. You get a startup tune, you load it and run the car in the driveway and follow the provided instructions. You send those logs for a basic driving tune. Then you datalog on the street and send THOSE back.
After that tune you are pretty much good but you can take the car to a dyno and get on Wi-Fi with a laptop and have time booked concurrently with the remote tuner and have him tune you on the dyno.
Or just find a real good local tuner lol.
The OP should definitely be getting a wideband tho. Running without one is a no no.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 06-19-2015, 11:11 AM   #12
Straybullitt i think i will just add an charger on these cams then
Old 06-19-2015, 11:36 AM   #13
Yep, supercharger with PI cams will max out what the stock motor can take.
I still recommend the Novi 2000. About the same price as the Vortech S trim except the Novi 2000 moves a LOT more air and is on par with the T trim.
Cams before supercharger or after? fordmustang3.8 Pre-2005 V6 Mustang 16 02-23-2015 09:03 AM
Supercharger with ford racing cams?? Madison917 2005-2010 Mustang GT 1 07-22-2014 09:29 AM
Supercharger or cams Enderthreesix 1996-2004 Mustang GT 3 07-17-2013 03:51 AM
cams and heads or supercharger chris25 1996-2004 Mustang GT 7 09-17-2012 09:00 PM
Supercharger Cams and head mods BIGRED3361 2005-2010 Mustang GT 25 12-12-2010 09:29 PM
» Members Mustangs
Mustang
lenko
"Julie"
BIG_K
Add your Mustang
01:04 PM
