Misfire/sputtering - Mustang Evolution
Old 06-16-2015, 03:00 PM   #1
Misfire/sputtering
Got a issue with my 96 gt. what's happening is as soon as I start up it runs fine for about a min or 2 and then if I get it to much throttle it sputters but if i back of the throttle and just ease into it slowly it won't sputter or miss. I changed plugs and no difference. I'm thinking it has something to do with a sensor just not sure which one. I'm throwing a purge valve code and misfire codes 7 and 2.
Willwyatt627 is offline   Reply With Quote
Old 06-16-2015, 04:10 PM   #2
Could be a number of things. When is the last time you did the coils and plugs?
Sent from my LG-D801 using Mustang Evolution mobile app
Old 06-17-2015, 01:03 PM   #3
Did coil packs and plugs 2 weeks ago. Just odd that I can ease into throttle with now miss up to 5k but if I give it just a little to much I misses/stutters but mainly under load
Old 06-17-2015, 01:36 PM   #4
Did you torque the plugs to 12-15ft lbs? Hopefully you did not overtighten. If you used cheap coils it could also be that.
Did this problem happen after you did the plugs/coils or was it present beforehand?
Old 06-26-2015, 03:47 PM   #5
Before that's why I replace plugs and coil packs only thing I haven't done is plug wires
Old 06-26-2015, 10:58 PM   #6
infamous281's Avatar
Re trace your steps , check proper wire route.. check plugs , check for codes , clean maf , get fuel pressure , get new fuel filter, etc.
Sent from my SM-N910T using Mustang Evolution mobile app
Old 06-26-2015, 10:59 PM   #7
Wouldn't hurt to inspect wires. . Maybe one is cracked and is letting spark out..
Could check at night in the dark to see if it's sparking anywhere.
Old 06-28-2015, 09:15 AM   #8
johnathan2225's Avatar
Region: West Virgina
Do you still have cats on your exhaust? (Plugged up?) could be o2 sensor also.. I had this issue with my 4.6, and then I changed out exhaust, went cat-less and done an rear o2 delete, with help of my sct tuner, I turned off my rear o2's, and cleared my codes, and they haven't popped back up.. One code can throw a few codes.. For example; bad plug (misfire) may also throw code for air/fuel mixture, and throw codes for o2's.. All because of a plug..
Woooot!!!!!
5.0l auto, swapped out with 4.6l 5 speed, summit cold air, 17"saleen, cat delete, rear o2 delete, H-pipe, 94 body and rear end, 99 everything else..
johnathan2225 is offline   Reply With Quote
skip-sputtering Sn95er 1996-2004 Mustang GT 3 10-10-2011 11:53 AM
Still sputtering... 04SonicBlueGT 1996-2004 Mustang GT 7 11-30-2009 12:25 AM
Sputtering 04SonicBlueGT 1996-2004 Mustang GT 5 11-15-2009 07:24 PM
sputtering at low rpms eddie1 1996-2004 Mustang GT 28 05-12-2009 08:22 PM
sputtering Stang!! jagger969 1979-1995 Mustang GT 2 04-09-2008 09:02 PM
02:33 AM
