Misfiring ? - Mustang Evolution
Old 06-19-2015, 07:48 AM   #1
mustangt03's Avatar
Misfiring ?
2003 GT misfiring under torque and cruising, could it be coils. I just did a plug change not too long ago. Sometimes when I misses the radio makes the spark sound? So I would think it would be something to do the coils skipping.
mustangt03 is offline   Reply With Quote
Old 06-19-2015, 10:03 AM   #2
It is likely a coil, or coils, but you should check for any trouble codes. There may be a code pending even if the Check Engine Light is not on.
Old 06-20-2015, 07:07 AM   #3
mustangt03's Avatar
If I were to do all new coils what would recommend ?
Old 06-20-2015, 08:25 AM   #4
jeno's Avatar
OEM stock coils from ford
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 06-20-2015, 09:57 AM   #5
Yep. I won't use anything but the factory OEM Motorcraft coils...
Rockauto usually has the best price on them. There is a Rockauto discount code in the General Mustang forum.
Old 06-20-2015, 10:08 AM   #6
I just rebuild my coils. $30 for 8 boots and 8 springs. The electronic portion rarely goes bad.
Old 06-20-2015, 10:31 AM   #7
XSlashDashX's Avatar
Rockauto for rebuild?
Old 06-20-2015, 03:12 PM   #8
fenixignition's Avatar
yea i saw em on rockauto before. or amazon. And i agree on the coil packs. This is a common thread on mustang forums. the coil packs tend to "weaken" and cause problems under load, so as you accelerate at lower rpms, it will struggle. I would start with whats cheapest and work your way up. change the coil boots and springs as suggested above, if your plugs are old, change those, if you still have a problem then grab a coil, and swap it out with another until the problem goes away. hopefully its just one, and not 2.
2002 GT 5sp. 16x,xxx miles
Old 06-20-2015, 06:56 PM   #9
Yep or Amazon.
Old 06-22-2015, 08:50 PM   #10
mustangt03's Avatar
I figured OEM , I'll probably just do them all, she struggles bad low at Rpms under load . That's gotta be it
Old 07-12-2015, 01:34 PM   #11
jeno's Avatar
Well fixed my misefire today did my plugs new coil boots the misefire was on #5 had coolant in the hole from when I did the intake didn't notice it before all cleaned up and no misfire also cleaned the engine up a bitClick image for larger version
99 mustang misfiring during hard throttle 1quick4.6 1996-2004 Mustang GT 5 02-28-2012 11:53 AM
EVAP Help P0455 CEL and now random misfiring 3ntr0py Pre-2005 V6 Mustang 11 01-24-2012 01:37 PM
Misfiring problems Stockish302 1979-1995 Mustang GT 14 11-15-2011 01:08 PM
misfiring need help austinknoll Pre-2005 V6 Mustang 11 08-17-2011 12:27 AM
Cylinder Misfiring? Jeremym831 1996-2004 Mustang GT 4 02-05-2008 12:12 PM
11:56 AM
