Lower Control Arms - Mustang Evolution
Old 06-22-2015, 10:42 AM   #1
escottcarp's Avatar
Lower Control Arms
I'm looking at getting a set of rear lower control arms for my '02 DD. Does anyone have any preferences or any stay-away-from suggestions?
Thanks
Smoke tires, Not drugs!!
escottcarp is offline   Reply With Quote
Old 06-22-2015, 10:43 AM   #2
Get Maximum Motorsports
/thread
Old 06-22-2015, 11:16 AM   #3
XSlashDashX's Avatar
Get SR upper and lower
Joke....
Get MM.
Old 06-22-2015, 11:26 AM   #4
Joke....
Get MM.
Lmao.
Agreed. Max Motorsports or don't even bother.
The Steeda ones are the only other ones I've had that don't suck but they're not as good as the MM.
Old 06-22-2015, 05:33 PM   #5
escottcarp's Avatar
Ok. What is the benefit of poly bushings?
Old 06-22-2015, 06:13 PM   #6
Poly is most comfortable.
Prothane is a good middle ground between comfort and stiffness
Spherical = race car
Old 06-22-2015, 06:18 PM   #7
Slater2111's Avatar
Just to touch on the spherical bearings, they have significantly more NHV, but will provide the most control of the rear end of the three.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 06-22-2015, 06:21 PM   #8
Yup. Not many people are willing to run spherical bushings on the street. It's like running solid motor mounts.
Old 06-22-2015, 06:27 PM   #9
Slater2111's Avatar
This one that maximum Motorsport offers sold on American muscle here
http://www.americanmuscle.com/maximu...rms-99-04.html
These offer a 3 piece poly bushing on one end and a spherical bearing on the other end. Great compromise and better than poly on both ends.
Old 06-22-2015, 06:50 PM   #10
Those are what I've got. Great arms.
Old 06-22-2015, 06:51 PM   #11
escottcarp's Avatar
And I guess the rubber bushings Mustangs come with are softer and cheaper than Poly.
Old 06-22-2015, 07:16 PM   #12
Slater2111's Avatar
Exactly and about 2 inches of rear end deflection in turns.
Old 06-22-2015, 07:21 PM   #13
Except you need that deflection from the upper control arms which is why you should not put anything in to replace the stock uppers. The Steeda car I got has UCAs from them that they put in from the factory. I am going to have to be VERY careful of snap oversteer and suspension bind until I swap the SRA out with an IRS.
Old 06-22-2015, 07:23 PM   #14
I should be getting mine in possibly August. It would've been next week, but something on the list came up and for a lot cheaper. So that first...
Adventure till you drop.
Old 06-22-2015, 07:24 PM   #15
escottcarp's Avatar
Lower Control Arms
I've read a few comments saying to KEEP the original upper control arms when replacing the lowers. No one gave a reason for that. Thx!
Recon, have you selected a brand?
Old 06-22-2015, 07:28 PM   #16
are you wanting to do a rear sway bar also?
newedge01 is offline   Reply With Quote
Old 06-22-2015, 07:29 PM   #17
That really isn't going to do a whole lot honestly. If the stock one isn't broke... roll with it.
Old 06-22-2015, 07:29 PM   #18
Slater2111's Avatar
^ snap oversteer is a dangerous condition in which the rear end doesn't do what it should. It basically gets away from you and there's almost no way to control it once it's entered snap oversteer. Also the uppers are known to shear the upper control arm mounts out with many upgraded upper control arms. Trust us. Leave the uppers factory.
Old 06-22-2015, 07:30 PM   #19
Yeah I know but the car came with them like that. I may honestly get a set of stockers out of a wrecked car and swap them in to be safe.
Old 06-22-2015, 07:38 PM   #20
Lower Control Arms
Yes, but it isn't the one they're suggesting to you. Which my car is strictly a show car, not a race car. I'm looking for some improvement but not anything too extreme. Maximum motorsports is the best no doubt, but a few years back someone gave me a ride in their car. I was impressed with the handling performance. So I'm basically putting everything he did to the suspension, minus a couple of things. I'm having difficulty locating some parts. Hopefully, they're actually out there, and I'm not just searching for something that's no longer on the market...
Plus my car has a wheel hop reduction kit on it...
Old 06-22-2015, 07:49 PM   #21
Slater2111's Avatar
I was referencing your post about the snap oversteer for the OP. I know you know Scotty.
Old 06-22-2015, 08:13 PM   #22
escottcarp's Avatar
-I'm planning to keep the rear sway bar. Just install it on the new LCA's.
-The MM Sport LCA runs a little more than I want to spend. I don't have a budget, but don't want to get in trouble with the Mrs. On the other hand, I don't want to have to replace an LCA or bushings in a year or two because the new cheapo bushings failed. I don't drive fast or go to the track, so I should be good with almost any good control arm......
Old 06-22-2015, 09:18 PM   #23
If you are going "budget" then get the Steeda lowers.
Old 06-23-2015, 09:57 AM   #24
You could do a poor mans 3 link for the time being.
Old 06-23-2015, 11:32 AM   #25
If I was going to stay SRA I'd pop a PHB in there and remove a UCA. But I am going to go IRS with this car. That is hopefully going to be the one thing I buy for myself with next year's tax returns and put the rest in the bank.
Old 06-23-2015, 11:32 AM   #26
escottcarp's Avatar
LCA's: here is my current selection thinking. This is only in the order I wrote them on paper as I did my research, so, not in order of fav to nope.
SR: they have good reviews on AM!
J&M #30009: maybe more tuned for drag racing than DD.
Steeda 555-4421: good cause it's Steeda!
UMI Performance 1022-B: from a made-in-America Pennsylvanian suspension company
BBK Gripp: very popular like Steeda.
Any thoughts? Thanks in advance.
Old 06-23-2015, 11:35 AM   #27
Yeah, Steeda if on a budget, MM if you want the best one. The rest are cheap and not recommended.
"Good reviews on AM" should never really be taken without a grain of salt. I'd say most of them are ppl who just got finished installing XYZ product and have not even had a chance to give it a few days/weeks to see how it actually is. That or they have no basis of comparison except vs the stock stuff they removed.
Old 06-23-2015, 12:16 PM   #28
escottcarp's Avatar
Reviews?? The review I never can believe on any site is the one where the customer has the product and hasn't used/installed it!!!! Aargh!! They are reviewing that the product arrived undamaged and looks like the web pic, I guess????
Anyway, thanks for the feedback.
Old 06-23-2015, 12:32 PM   #29
infamous281's Avatar
Spherical TeamZ adjustable lowers here , launches good.
Not so street friendly.
Sent from my SM-N910T using Mustang Evolution mobile app
Old 06-23-2015, 03:46 PM   #30
Lower Control Arms
That's how it goes most of the time. What the sites should do is make them install the part and test it, before leaving feedback on it. Or give the option of feedback on part's description then another feedback on car's performance before and after install...
And possibly feedback on the installation, of possible tools needed and maybe potential headaches will installing, that aren't mentioned on the site...
Old 06-23-2015, 04:20 PM   #31
Maximum Motorsports..... Don't think about it. Just do it.
Old 06-23-2015, 07:21 PM   #32
That won't ever work because the companies love their 5 star "omg this new part got in and look at bling on my car omg TY" and then after a week the person is like "actually this isn't that awesome" but they've already written their review. Also I've written bad reviews on AM before that never showed up. So...
Old 06-23-2015, 07:24 PM   #33
Key word... "SHOULD"
I know it'll never happen; I know I'm just dreaming...
It would be nice if it did happen...
Old 06-23-2015, 07:30 PM   #34
That's what google and internet forums are for. You see SR CC plates with what like 5 stars on AM?
Simple google search and a few random forum thread reads will let you know they are huge pieces of ****.
For Sale: Bmr upper control arm, lower control arms and relocation brackets blacked out gt Mustang Parts for Sale and Wanted 26 05-30-2014 09:04 AM
lower control arms vs. upper control arms 13 stang22 2011-2014 V6 Mustang 24 05-08-2013 06:03 AM
Hotchikus lower control arms question dana 1979-1995 Mustang GT 14 02-03-2006 06:58 PM
which lower control arms to get? mild2002gt 1996-2004 Mustang GT 11 01-16-2005 11:54 PM
Lower control arms Rick0636 Pre-2005 V6 Mustang 10 07-15-2003 03:43 PM
06:16 PM
