A bad lifters/rocker? - Mustang Evolution
Old 06-23-2015, 03:27 PM   #1
Ahmed ali khan's Avatar
Hey everyone
Its been few months when i start my car in the morning i hear loud noise as of something spinning (must be clutch and flywheel noise) just in few seconds noise gets quiet
It happens whenever i start the car when its cold and when the car is warm up the noise goes away
Ive order clutch plate and flywheel
But haven't install yet.
And when i drive the car few days back i heard a ticking noise while driving, from 2000rpm onwards
Is that a bad rocker ?
And even wen I neutral the car and press gas paddle i hear same ticking noise as rpm passes 2000
The noise is like ticticticticn
Ahmed ali khan is offline   Reply With Quote
Old 06-23-2015, 03:44 PM   #2
XSlashDashX's Avatar
Sounds like the same noise mine makes.
---------- Post added at 04:44 PM ---------- Previous post was at 04:44 PM ----------
And you can't hear it from the motor. I can only hear it in the vehicle. Previous owner said clutch has been replaced but i doubt it.
Old 06-23-2015, 05:10 PM   #3
Slater2111's Avatar
Could be lash adjusters going bad.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 06-23-2015, 05:35 PM   #4
Check for exhaust leaks.
My clutch assembly makes some noise during cold starts also.
Old 06-23-2015, 06:07 PM   #5
infamous281's Avatar
Video would be helpful
Sent from my SM-N910T using Mustang Evolution mobile app
Old 06-28-2015, 09:34 AM   #6
johnathan2225's Avatar
Region: West Virgina
I'm gonna try and figure out how to post a Video of mine with it's issue, maybe you guys can help me..
Woooot!!!!!
5.0l auto, swapped out with 4.6l 5 speed, summit cold air, 17"saleen, cat delete, rear o2 delete, H-pipe, 94 body and rear end, 99 everything else..
johnathan2225 is offline   Reply With Quote
Old 06-28-2015, 09:50 AM   #7
http://youtu.be/phPqVFHtwbA
Woooot!!!!!
Old 06-28-2015, 10:30 AM   #8
jeno's Avatar
Sounds like a lifter or rod knocking
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 06-28-2015, 10:35 AM   #9
jeno's Avatar
I saw you pulled the motor but it still sounds like a rod knock or a lifter did you look inside the pans for any dents
Old 06-28-2015, 10:39 AM   #10
Ya I looked in all pans for obvious signs, and there was nothing..:/
Woooot!!!!!
Old 06-29-2015, 12:05 PM   #11
Oh wow. Mine sounds nothing like that.
Old 06-29-2015, 12:15 PM   #12
Lol
Sponsored at;
http://www.carsponsors.com/dap/a/?a=86212
Old 06-29-2015, 02:58 PM   #13
Like i said earlier. Can't even hear it from the hood. Only when in the car. I think it's exhaust leak or something to do with my clutch. If they make noises like that. Sounds like my radiator fan is rattling but it's definitely not it.
Old 06-29-2015, 03:34 PM   #14
I would take off the valve covers to see if a rocker arm or lifter came off or is jacked up..
Before taking out the engine.
Old 06-29-2015, 09:11 PM   #15
I finally found my issue!!!!! It was a spun bearing.. I'm gonna micro measure and hope it is all still good, and replace all bearings, and put it back together.. Yay!!!!! It took some rigging to get number 8 to actually show play in the bearing, but I finally got it..!! Lol I'm so f n happy.. Now puzzle solved..
Sponsored at;
Old 06-29-2015, 09:40 PM   #16
jeno's Avatar
Sponsored at;
Good job
I think my lifters have gone bad. Haav2 1979-1995 Mustang GT 18 10-23-2016 12:54 PM
solid roller lifters, pushrod 5.0 lifters in V6?? lemons95 Pre-2005 V6 Mustang 2 08-23-2014 09:27 AM
rocker arms/lifters blackGT91 1979-1995 Mustang GT 5 10-15-2012 07:30 AM
Bad Lifters? Please help.. FORDGT14 1996-2004 Mustang GT 0 01-22-2012 03:03 PM
What lifters are these? ridelikehell The Bar 3 12-27-2003 01:15 AM
12:07 PM
