EGR help - Mustang Evolution
Old 06-24-2015, 04:21 PM   #1
keeney35's Avatar
EGR help
Okay I've researched for ever I've found tons of threads about it but none of them actually tell you what to remove and how to go about doing it..
I was going to wait to do this until I did my header install but I'm getting impatient so I'm gonna do it now..
I understand how to take the tube off the manifold and screw on the cap and do the plate on the plenum..
My questions are what vacuum lines, sensors, wiring, and other EGR stuff can I delete along with the valve and how do I do that? I know some vacuum lines with really screw things up if they aren't hooked up so I don't wanna grab the wrong stuff.. Once I get this info I'm gonna do a really in depth write up, to save future headaches for people
keeney35 is offline   Reply With Quote
Old 06-24-2015, 04:23 PM   #2
EGR Delete Write-Up - Forums at Modded Mustangs
Old 06-24-2015, 04:53 PM   #3
keeney35's Avatar
Soccer you da man, this is one thread I hadn't seen yet..
Old 06-24-2015, 05:23 PM   #4
Old 06-24-2015, 07:59 PM   #5
Yep, I'm not putting any of that **** back in my car when the new engine goes in. I swear to god I'm going to get moving on that car this weekend... Seeing way too many nice stangs on the road is driving me nuts.
Just make sure when you do that you have the EGR shut off in the tune.
Recommend deleting the PCV also but that's just me. The less vac lines and pointless **** in the engine bay the better.
Old 06-24-2015, 08:35 PM   #6
keeney35's Avatar
How do you delete pcv? I won't be able to get a tune for at least a month so would the pcv delete require an immediate tune? I've seen people put the breather filters on the valve covers I'm assuming that is part of it? Anything that I can delete that is unnecessary I want to do lol
Old 06-24-2015, 08:43 PM   #7
The PCV is ventilation for the crank case. So when you delete the lines running from crank case to the intake you still need some way to ventilate it. Some people put breathers right on the valve covers. Others will run an external breather/catcher. But that will require new lines.
Old 06-24-2015, 11:11 PM   #8
keeney35's Avatar
Any driving issues if you delete that hose? I'm assuming it's the one that runs from the drivers valve cover to the intake tube and have the black box in the middle
Old 06-25-2015, 10:20 AM   #9
keeney35's Avatar
I looked all around and can't find a thread with pics that actually shows what gets deleted and where I'm not even sure what all hoses I can and cannot delete
Old 06-25-2015, 12:07 PM   #10
keeney35's Avatar
I'm gonna leave the pcv alone right now and worry about finishing this EGR delete.. I've got the tube off of the manifold and no as far as all of the crap up top..
Name:	ImageUploadedByMustang Evolution1435255303.355435.jpg
I know this is the EGR valve.. That's where my plate goes.. That's pretty straightforward.
But what do I need to do with the green vacuum line off the top of itClick image for larger version
Name:	ImageUploadedByMustang Evolution1435255370.286229.jpg
Name:	ImageUploadedByMustang Evolution1435255395.198823.jpg
ID:	185762 this sensor is either the dpfe or EGR so what do I need to do with it, and I remove that entire bracket and just unhook and hide those sensors?
Name:	ImageUploadedByMustang Evolution1435255456.663445.jpg
Name:	ImageUploadedByMustang Evolution1435255479.608247.jpg
ID:	185764 this red vac line runs over to a Y coupler in front of my plenum what should I do with these Click image for larger version
Name:	ImageUploadedByMustang Evolution1435255540.637454.jpg
ID:	185765Click image for larger version
Name:	ImageUploadedByMustang Evolution1435255556.794032.jpg
Need some help ASAP on this fellas as its already apart and it's my daily lol I just need to know what's part of the system that I can just unplug and tuck away and also what vacuum lines can I just cut and cap because I had a vac line break when I installed my plenum and I had to basically ghetto rig it back because it made my idle all kinds of ****ed up
Old 06-25-2015, 01:34 PM   #11
keeney35's Avatar
Name:	ImageUploadedByMustang Evolution1435260700.471906.jpg
Got this sensor of the u shaped bracket I think this is the dpfe correct me if I'm wrong. The green vac line was on top of the EGR valve and goes to this and the red line that comes off of this sensor goes to a coupler in front of the tb
Name:	ImageUploadedByMustang Evolution1435260802.256157.jpg
This was also on the bracket with the sensor above its got a sensor and two hoses coming off of it. What is it? Can it be removed.. Where do the hoses go?
Old 06-25-2015, 01:50 PM   #12
keeney35's Avatar
Also with this sensor from what I've read on the thread soccer posted most people are cutting the vac lines and putting a screw in the hole since they are the EGR related and DPFE so instead of the screw can I put those vacuum line caps on there?Click image for larger version
Name:	ImageUploadedByMustang Evolution1435261719.960075.jpg
Name:	ImageUploadedByMustang Evolution1435261772.501543.jpg
Progress so far
Old 06-25-2015, 09:33 PM   #13
keeney35's Avatar
Well I figured it all out and re routed my vacuum lines
Name:	ImageUploadedByMustang Evolution1435288897.238508.jpg
ID:	185818Click image for larger version
Name:	ImageUploadedByMustang Evolution1435288909.844423.jpg
I deleted the EGR valve, the green vac line that was on top of it, the EGR solenoid and 2vac lines that come off of it red and the other end of the green one, the DPFE sensor and the two hoses that go to the EGR tube.
Right in front of the Tb is a few Y couplers for the vac lines.. I pulled them all off.. Click image for larger version
Name:	ImageUploadedByMustang Evolution1435289229.934509.jpg
There was two Y couplers before and 3 diff lines.. What I did was remove the Y couplers, the only one I left was the one that went directly to the TB, the two red lines that go into that coupler is the one on the right from the FPS and the left one goes back to the passenger valve cover but it's hidden.. Rerouting the lines this way really cleans it all up.
Engine is a little dirty but here is the finished product Click image for larger version
Name:	ImageUploadedByMustang Evolution1435289461.698563.jpg
ID:	185823Click image for larger version
Name:	ImageUploadedByMustang Evolution1435289473.654136.jpg
I'll clean it up really good tomorrow and post some better detailed pics of everything..
Can some one chime in on putting the breather on the drivers side valve cover? And deleting the PCV stuff.
Old 06-25-2015, 10:44 PM   #14
Good job. Sorry I wasn't much help besides that link lol. I've been thinking of doing it myself also. Never been good at this type of stuff.
Old 06-25-2015, 11:01 PM   #15
keeney35's Avatar
It was really easy I wouldn't have asked for help if it didn't involve the vac lines cause I know some of those can be detrimental to the driving.. But it's super simple I'm gonna post a good how to in the next day or so
Egr valve and tube help! 44bangstang 1996-2004 Mustang GT 0 03-15-2014 08:26 PM
VAP Intake Spacer- EGR Tube Extension HELP robb15033 Pre-2005 V6 Mustang 1 03-29-2012 06:52 AM
EGR flow insufficent el cheapo Pre-2005 V6 Mustang 2 04-25-2004 11:04 AM
EGR delete kits Stylin97V6 Mustang Parts for Sale and Wanted 8 03-05-2004 09:04 AM
EGR flow insufficent (repost of thread in ECU) el cheapo Pre-2005 V6 Mustang 5 12-04-2003 12:08 AM
07:13 AM
