T45 Transmission Clutch Fork/TO Bearing Engagement - Mustang Evolution
Old 06-24-2015, 05:53 PM   #1
-Can someone tell me once and for all whether or not the TO bearing is engaged and spinning all of the time or if it not spinning when the clutch is released?
What is normal, as designed?
Why are so many set-ups different? Some adding springs to release the bearing, ect..
______-------------------------------__________----------------------___
I'm about to replace the clutch. I have to take it to a shop. I want it done right.
~Got a McLeod clutch kit, FRPP TO & Pilot bearings, MM clutch cable kit, TO bearing retainer sleeve, clutch fork pivot ball stud, and plan on picking up a new clutch fork.
All help appreciated, Thanks.
Old 06-24-2015, 07:47 PM   #2
The correct way is to have the TOB spinning at all times. They are designed this way and a good OEM bearing will last a long time.
They are designed to always be spinning because you do not want the bearing shocked going 0-whatever RPM in a split second vs ramping up gradually with the motor. Those "freeplay" setups are hell on the bearings and the clutch fingers not to mention you'll get a slight burnt metal smell when you first turn the car off.
Old 06-28-2015, 08:54 AM   #3
Thank you, thank you.
Want to throw this out there now-
-I have a throw out bearing from FRPP. It has the same number stamped on it as a Ford OEM bearing listed on sites.
Differences??
Clutch fork/pivot stud Help please! RodgersMustang 1996-2004 Mustang GT 2 06-16-2014 08:44 PM
Clutch cable problems or fork maybe? 04gtdriver85 1996-2004 Mustang GT 18 11-22-2013 04:10 PM
Clutch Fork Rattle xhgwx SVT Mustang 5 11-05-2013 07:02 PM
Clutch fork counterweight? ab_mach1 1996-2004 Mustang GT 10 10-27-2012 04:44 PM
01:41 PM
