I Need Help - Mustang Evolution
Old 06-25-2015, 12:17 PM   #1
I Need Help
So my 2000 Gt is at a shop getting a new engine since my old one locked up on me. I have a problem. My old engine has 8 holes for the fly wheel, and the new one ima get has 4 why is this? My stang is stick is there a difference or so?
Justang2000 is offline   Reply With Quote
Old 06-25-2015, 01:01 PM   #2
Your new engine probably has a 6 bolt crankshaft. You will need to get a 6 bolt flywheel to bolt up to it.
Keep your old engine! It most likely has a forged steel crankshaft that you can remove and sell to help offset the cost of your new engine!
Old 06-25-2015, 03:00 PM   #3
What do you mean to offset?
Old 06-25-2015, 03:01 PM   #4
Ohh nvm I re read it
Old 06-25-2015, 03:10 PM   #5
Lol.
I meant to say that if that 8 bolt crankshaft is forged, and is still in good condition, they are worth at least $300.
Old 06-25-2015, 03:12 PM   #6
Originally Posted by straybullitt View Post
Lol.
Whats the difference in the crank shaft? Does it make it more kick ***?
Old 06-25-2015, 03:29 PM   #7
Forged steel cranks are stronger than cast iron crankshafts. A cast crank is good for up to about 600 hp, so unless your plans are to build a "monster", a forged steel crank isn't really necessary.
Old 06-28-2015, 11:15 PM   #8
I mean I dnt wanna build a monster. Buuut I dnt mind aggression. I want more aggression out of her. So I just might get her cammed
Old 06-29-2015, 07:20 AM   #9
His 8 bolt GT crankshaft is cast, not forged. Its a Windsor crank. New flywheel will need to be 6 bolts most likely for a 6 bolt crank.
Need 12v under hook, need help with headlight wiring dseg 2011-2014 Mustang GT 0 06-17-2015 08:49 PM
Need quick help! Need to find 4.10 gears for 2010 v6 mustang?? Camaro Eater Pre-2005 V6 Mustang 2 06-08-2010 05:31 AM
Guys need help.. going to get new engine.. need advice Skyes97Stang Pre-2005 V6 Mustang 9 11-28-2009 12:35 AM
need some help from the electrically inclined (need to find a power transformer) fast64 The Bar 5 05-26-2006 03:58 PM
Need to choose new tires..need help KyleUSAF Mustang Wheels & Tires 13 11-29-2005 11:13 AM
04:27 PM
