Exhaust bolts keep loosening - Mustang Evolution
Old 06-25-2015, 02:10 PM   #1
robin_gt's Avatar
Hey guys,
So the bolts that connect my midpipe to headers and midpipe to cat back keep loosening and are causing exhaust leaks. For example i tightened all the bolts and the car drove fine for about 2 heat cycles, then the leaks started. Now are there any tricks to keep those nuts from backing off it gets really annoying.
I also did 3 runs at the strip yesterday and i was kind of disappointed. I ran 14.3-14.5 @95-97 mph, and i have longtube headers, o/r x pipe and headers, 4.10 gears, 315 sumitomo tires, frpp intake manifold and bama race tune, its a 5 speed. Does that seem kinda slow for those mods? Let me know!
robin_gt is offline   Reply With Quote
Old 06-25-2015, 02:26 PM   #2
natestang07's Avatar
I would try some loc tight and then it those don't work maybe look into those expensive locking bolts
Old 06-25-2015, 02:35 PM   #3
oxford5pointoh's Avatar
Stage 8 locking fasteners work awesome. I'd just go that route. I had them on my 69 mustang and they never leaked.
IG @Oxford5pointoh
Old 06-25-2015, 02:36 PM   #4
robin_gt's Avatar
doesnt loctite break down at heat?
Old 06-25-2015, 02:38 PM   #5
robin_gt's Avatar
IG @Oxford5pointoh
i dont know if were on same page here lol, im talking about the studs that connect the midpipe to longtube header and cat back not the manifold bolts that bolt up to the engine, i used the stage 8 bolts when i installed the l/t headers and they are not leaking, the midpipe is. but the nuts that sit on the studs keep backing off.
Old 06-25-2015, 02:44 PM   #6
robin_gt's Avatar
maybe i could tap the threads nearest to the nut when i tightened everything down with a flathead screwdriver and hammer i think that would prevent them from backing out
Old 06-25-2015, 03:03 PM   #7
Slater2111's Avatar
You're way over thinking this. If you have enough thread on the bolts you can always add one more nut on each bolt. Tighten the new nut to the old nut and you're set. Jamb nut it.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 06-25-2015, 03:08 PM   #8
robin_gt's Avatar
lol thats a good idea imma pick up some bolts later thanks for the idea
Old 06-25-2015, 03:10 PM   #9
Slater2111's Avatar
No problem
Old 06-25-2015, 03:14 PM   #10
My bad. Yeah I was honking header bolts. The jamb but is the way to go as mentioned.
IG @Oxford5pointoh
Old 06-25-2015, 03:29 PM   #11
Mile high JDF's Avatar
Hey guys,
They got you squared away on the exhaust. As far as your track times though, what altitude are you racing at? Do you happen to know any of the weather stats from that night in order to calculate density altitude?
My local track is right around 5280' with a density altitude usually somewhere in the 7000s, so we run much slower times than the guys at sea level. My old GT would run l low 15s all night and that was considered quick for a bolt on new edge.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-25-2015, 03:33 PM   #12
robin_gt's Avatar
im in south florida so im right at sea level it was about 88 degrees with 70% humidity, i got wheelspin at launch so i had to let off the gas to correct it, i launched @2500 rpms.
Old 06-25-2015, 05:06 PM   #13
Jbone007's Avatar
Just from what I have read a stock GT should run around the same times you are posting. If you are spinning to much on launch that is what is killing your times, May look into some suspension mods for better traction, and some Drag Radial.
Jbone007 is offline   Reply With Quote
Old 06-25-2015, 05:27 PM   #14
A stock GT should run about 14 seconds flat in ideal atmospheric conditions.
You had a higher than sea level density altitude that you need to correct your times for.
And if you had a disappointing 60', your ET is going to reflect that.
exhaust
Starter bolts keep loosening on my 86 Mustang GT. What's up with this? jdb68 1979-1995 Mustang GT 2 03-11-2015 03:28 PM
Seat belt loosening Johnstars79 2005-2010 Mustang GT 2 12-19-2012 04:08 PM
bolts bolts bolts! bcosta56 1979-1995 Mustang GT 8 10-10-2012 03:08 PM
Stage 8 bolts, but no bracket bolts? CreationNation 1979-1995 Mustang GT 1 04-13-2009 10:00 AM
To keep or not to keep JaketheSnake Pre-2005 V6 Mustang 1 10-13-2006 11:56 AM
07:36 PM
