A/C problem, I need help - Mustang Evolution
Old 06-26-2015, 02:22 AM   #1
Hello everyone, I have a 2001 mustang gt. I was driving the car today and I noticed it wasn't blowing cold air anymore. So I noticed the clutch isn't engaging. I can turn the clutch freely but it wont engage. Anyone know what it could be? Thanks in advance, Albert.
03redzo6 is offline   Reply With Quote
Old 06-26-2015, 02:49 AM   #2
bucko's Avatar
Does the clutch engage at all, meaning for a few short seconds, then disengages? This would be an indication of no pressure (loss or Freon due to a leak).
Otherwise it could be the pressure switch, A/C clutch, or dash switch/connection to A/C clutch.
With a test light or multimeter, you could test the dash switch (A/C activation) by turning the key to on (don't start), unplug the connector that plugs onto the A/C clutch, and see if you have voltage. That rules that as the fault or not. If that checks good, then I'd steer towards a leak causing no pressure (and with this, the A/C clutch will cycle on/off over and over), or the pressure switch does not detect pressure in the system. You'd need gauges for this test.
Old 06-26-2015, 01:17 PM   #3
What Bucko said.
But check your AC fuse first.
Problem...need help! Sublime782 Pre-2005 V6 Mustang 3 08-16-2007 10:23 AM
Mach 460 headunit "CD error" problem, need help fast64 Mustang Audio & Video 7 05-02-2005 07:32 PM
Need some help with a calculus problem BruThru2002 The Bar 5 10-28-2004 01:33 PM
Need Help with Problem... 96GTwhite 1996-2004 Mustang GT 7 10-01-2004 10:40 AM
i'm having a problem. need help. Black00GT 1996-2004 Mustang GT 4 06-17-2004 04:02 PM
02:16 PM
