04 2v longtube install - Mustang Evolution
Old 06-27-2015, 06:44 PM   #1
keeney35's Avatar
How big of a pain is it to install long tubes? I've had these headers since February and I'm tired of them not being on so I'm getting tempted to tackle the install myself but idk how crazy this is to do
keeney35 is offline   Reply With Quote
Old 06-27-2015, 06:50 PM   #2
infamous281's Avatar
It's not so bad , a partner would be helpful.
Sent from my SM-N910T using Mustang Evolution mobile app
Old 06-27-2015, 07:46 PM   #3
Depends on what brand , what tools , where you going to be working at.
Old 06-27-2015, 07:48 PM   #4
Slater2111's Avatar
Might want to think about doing motor mounts while you're there at the k member and have the engine freed up too.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 06-27-2015, 08:12 PM   #5
keeney35's Avatar
What motor mounts do yall suggest
Old 06-27-2015, 08:28 PM   #6
keeney35's Avatar
And I will probably have access to a lift and an impact
Old 06-27-2015, 09:34 PM   #7
BigB227's Avatar
I did mine in my driveway, with just jack stands and a jack. Also replaced the mounts with polyurethane ones and put a PA racing Tubular K member on. Was it a PITA? Yes no question. Is it impossible? Not at all. Take time and plan at least a whole day maybe two depending on your experience and knowledge. Yes a partner helps out tremendously.
BigB227 is offline   Reply With Quote
Old 06-27-2015, 09:58 PM   #8
keeney35's Avatar
Do you really have remove your wheels, brakes, springs, spindles and steering shaft and stuff?
Old 06-27-2015, 11:28 PM   #9
Dropped my whole k member , and lowered engine on the ground .. it's enough room to put everything on ..
Use ford oem gaskets , stage 8 locking bolts on as many as you can get to..
Motor mounts just get them from ford. Oem parts.
Old 06-27-2015, 11:45 PM   #10
You drop the whole K. Also a good time to do the K if you have the scratch. UPR for weight savings/drag, Max Motorsports for handling/best quality.
Stage 8 locking bolts on ALL of them, you can get to them all with the K out.
Motor mounts... lol no not OEM. OEM uses little rubber pads in between the metal plates. Energy Suspension poly ones or don't even bother. Get the mounts and the trans mount too, you can buy them on Jegs or Summit. Don't get the AM ones or the Prothanes, those are **** quality urethane and also raise the engine up higher than stock. Energy keeps it spot on.
Now for the longtubes... if they aren't Kooks or ARH I wouldn't bother. If they are the Pacesetters or Pypes I REALLY wouldn't bother.
Old 06-28-2015, 12:53 AM   #11
robin_gt's Avatar
I dropped the whole k member, its not a pita it just takes alot of time. I did mine by myself in 3 days working about 5 hours a day. I got poly motor mounts, when i pulled my old ones out the rubber was all messed up and the motor mounts made a huge improvement i used the stage 8 header bolts only on the studs that came out during the install, about 4-5 came out when i removed the old headers. On the bolts that came off the old studs without taking the whole studs out i used split washers to keep the bolts on there and no leaks yet, i used ford racing manifold gaskets from AM. Just plan everything and make sure you have all the tools. Good luck
robin_gt is offline   Reply With Quote
Old 06-28-2015, 09:06 AM   #12
Speed_Mister's Avatar
Region: Arkansas
It's not hard, just drop the k-member and the headers are gonna be right there in your face. Took me and one other friend 5 hours to install on a lift.
2004 Mustang GT 5 Speed Full Bolt On 370rwhp 440rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 06-28-2015, 10:39 AM   #13
keeney35's Avatar
I'm gonna be on it non stop all day so I have the time, and i have access to a drive on lift so that's just the same as using jack stands if I'm dropping the k member..
Not saying I have pacesetter.. But I know they used to be **** quality but I got a set of longtubes for my drag truck about 6-7 months ago and they were really nice, decent gains on the dyno, no leaky welds or anything like that.. Any longtube has gotta be better than stock manifolds.. And why pay 1200$ for kooks when you can get a set for 300-400 and maybe get 2 hp less
Old 06-28-2015, 12:08 PM   #14
keeney35's Avatar
Is there a how to anywhere on how to drop the k?
Old 06-28-2015, 12:13 PM   #15
jeno's Avatar
http://www.modularfords.com/threads/...6/topics/27083
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 06-28-2015, 01:03 PM   #16
keeney35's Avatar
Thanks jeno, so you think it's doable with just 4 jack stands? No lift and an impact?
Old 06-28-2015, 01:14 PM   #17
jeno's Avatar
Sure if your mechanically inclined definitely doable but better with a helper
Old 06-28-2015, 01:25 PM   #18
keeney35's Avatar
I'll have my future father in law who was a mechanic for 25+ years to help so I think we can get her done
Old 06-28-2015, 01:26 PM   #19
jeno's Avatar
Should be no problem then maybe some stubborn bolts
Old 06-28-2015, 02:14 PM   #20
keeney35's Avatar
Nothing an impact can't fix lol
This isn't exactly related but I deleted my EGR the other day would that cause a slight gas smell on start up or when you get on it
Old 06-28-2015, 02:18 PM   #21
jeno's Avatar
Don't know still have my egr did you tune to compensate for the deleted egr
Old 06-28-2015, 02:58 PM   #22
keeney35's Avatar
Nope I just got it done Friday lol haven't had a tune yet gonna tune after I get the headers on probably if not then I will once the cams get installed because it will be a must
Old 06-28-2015, 02:59 PM   #23
jeno's Avatar
Don't forget to tune for egr
Old 06-28-2015, 03:03 PM   #24
keeney35's Avatar
Oh I will, I'm gonna tune to remove the EGR and no cats cause I now have codes for both
Old 06-28-2015, 03:09 PM   #25
jeno's Avatar
Good deal
Old 06-28-2015, 03:13 PM   #26
keeney35's Avatar
Any other pointers or tips with this install?
Old 06-28-2015, 03:26 PM   #27
natestang07's Avatar
Because the expensive ones won't rust away and decay lol
Old 06-28-2015, 03:27 PM   #28
Mine are pacesetter , great fit.
Wasn't going to spend 700+ on headers that are only going to give me 5-10 hp
Old 06-28-2015, 04:06 PM   #29
jeno's Avatar
Sounds like you'll be fine just take your time and don't rush it piece of cake
Old 06-28-2015, 04:46 PM   #30
keeney35's Avatar
Got the car up, working on taking off the O2 sensors snd h pipe now. Got the intake off, I'm not gonna drop the K, the instructions that came with the headers seem like they will work without dropping the k they just mention unbolted the motor and tranny mounts and moving them to slide each header in placeClick image for larger version
Name:	ImageUploadedByMustang Evolution1435531554.490974.jpg
Old 06-28-2015, 04:51 PM   #31
jeno's Avatar
Sounds good man you have plenty of room to work in
Old 06-28-2015, 09:17 PM   #32
keeney35's Avatar
Got the exhaust from the manifolds back out, had to stop and eat dinner and go get more beer lol Click image for larger version
Name:	ImageUploadedByMustang Evolution1435547734.337484.jpg
ID:	186065Click image for larger version
Name:	ImageUploadedByMustang Evolution1435547757.010770.jpg
The more I read I'm wondering if I shouldn't drop the k.. But I haven't found a good thread on how.. But does that mean k have to remove both wheels, brakes and all that good stuff?
Old 06-28-2015, 09:20 PM   #33
robin_gt's Avatar
Just do yourself the favor and drop the k member its just 8 bolts to drop it, dropping the k member is gonna save you alot of time.
Old 06-28-2015, 09:48 PM   #34
keeney35's Avatar
Do I have to do the brakes and all of that before I drop it or can I just do those 8 bolts and go
Old 06-28-2015, 09:51 PM   #35
robin_gt's Avatar
Take the brakes out, take the 2 strut to spindle bolts out, take the springs out and you're good to go
Longtube Install Slow4V 1996-2004 Mustang GT 7 09-02-2014 05:17 PM
Bbk longtube header install Chasafire888 1996-2004 Mustang GT 6 01-15-2014 08:46 PM
Longtube / Transmission install Slow4V 1996-2004 Mustang GT 4 12-28-2013 10:36 AM
Longtube Headers... now exhaust ?'s PA6shooter Pre-2005 V6 Mustang 10 03-17-2005 10:23 AM
MAC longtube headers plstktnkr2 Pre-2005 V6 Mustang 17 03-09-2004 09:55 PM
05:03 AM
