Anyone know how to fix these Codes? - Mustang Evolution
Old 06-27-2015, 10:06 PM   #1
Robbymyman's Avatar
Name:	ImageUploadedByMustang Evolution1435464347.338183.jpg
ID:	186012Click image for larger version
Name:	ImageUploadedByMustang Evolution1435464366.323078.jpg
ID:	186013Click image for larger version
Name:	ImageUploadedByMustang Evolution1435464380.758336.jpg
ID:	186014Click image for larger version
Name:	ImageUploadedByMustang Evolution1435464395.191073.jpg
Robbymyman is offline   Reply With Quote
Old 06-27-2015, 10:08 PM   #2
Robbymyman's Avatar
And I hope the last two are just the converters ( which I don't have) but the first two keep appearing and I know they are effecting my shifting and acceleration because when I erase them it feels as if I've jumped from my old V6 to a V8, but the moment they appear my acceleration and shifting turn to crap. Yes it's an automatic but there should be no reason as to why that when I floor it going 40 it doesn't downshift.
Old 06-27-2015, 11:34 PM   #3
infamous281's Avatar
Still running the egr ?
Those are egr codes ..
Sent from my SM-N910T using Mustang Evolution mobile app
Old 06-28-2015, 09:09 AM   #4
johnathan2225's Avatar
Region: West Virgina
New gas cap?
Woooot!!!!!
5.0l auto, swapped out with 4.6l 5 speed, summit cold air, 17"saleen, cat delete, rear o2 delete, H-pipe, 94 body and rear end, 99 everything else..
johnathan2225 is offline   Reply With Quote
Old 06-28-2015, 09:16 AM   #5
Check the gasket on your gas cap, or can be that it wasn't properly tighten.
Adventure till you drop.
Old 06-28-2015, 09:19 AM   #6
Jon3.7's Avatar
new gas cap and get rid of the egr
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 06-29-2015, 12:26 PM   #7
Robbymyman's Avatar
The EGR has been gone since I got the BBK plenum and throttle body, I haven't gotten a new gas cap yet but I will get that next. Now one thing I have noticed is when I fill my tank, the tube running from the gas cap to the gas tank leaks....like bad. After 10 minutes or so it stops and it only happens when I fill up. But this is really started to screw with me. The car has just about everything done to a naturally aspirated stand you can do and I hate losing ponies especially acceleration because of my stupid computer?
Old 06-29-2015, 01:18 PM   #8
Then if say that that is where you have your evap leak at, that could act as if your cap was loose..
Sponsored at;
http://www.carsponsors.com/dap/a/?a=86212
Old 06-29-2015, 01:49 PM   #9
Robbymyman's Avatar
Yeah, I had the codes removed when the EGR was removed. I didn't think about the fact that the system was reset not too long ago. I'll just get it retuned and hopefully that will fix the performer issue. I had the gas cap and tank checked and I have a leak in the hose connecting the too, still doesn't explain the performance though. But I'm hoping a retune would fix it, plus I have added quite a bit of mods since its last tune.
Old 06-29-2015, 03:23 PM   #10
Have you checked the fuel pressure? If it getting some air when it should be just gas, that can cause performance issues..
Sponsored at;
Old 06-29-2015, 03:41 PM   #11
Diehard's Avatar
Get that gas fill hose fixed first!!!
Old 06-30-2015, 12:01 PM   #12
Robbymyman's Avatar
Okay so it's not the hose it's the fuel gasket. I checked it out and there is a huge crack in it. It's pretty simple replacement and I've already ordered a new grommet. The only concern I still have is if that will fix my power issue? It's not the EGR, intake is clean, I don't have cats, and nothing is blocking airflow and I don't have any other codes popping up? If this doesn't fix it I'm probably going to go crazy.
Old 06-30-2015, 12:03 PM   #13
Kevin.Cook
Guest
Posts: n/a
A banana, rope, and some duct tape will patch that right up. Good luck
Old 06-30-2015, 02:43 PM   #14
Robbymyman's Avatar
Not sure what that means but I did successfully replace the grommet, which is a pain in a**. I also successfully broke off the security thing that prevents people from stealing your gas Click image for larger version
Name:	ImageUploadedByMustang Evolution1435696953.061335.jpg
ID:	186221 yay. I also managed to drop the other half of the old grommet in the gas tank. And after everything's finished in left with one screw. I don't where it goes, but I'll pray it wasn't important. Click image for larger version
Name:	ImageUploadedByMustang Evolution1435697004.666390.jpg
ID:	186222 long day for a piece of rubber.
Old 06-30-2015, 02:44 PM   #15
Robbymyman's Avatar
Hopefully this will solve my problems, if not, I'll be back
Old 06-30-2015, 07:25 PM   #16
WJL
Are you having other shifting problems other than not downshifting when you stomp on it?
WJL is offline   Reply With Quote
Old 06-30-2015, 07:27 PM   #17
Robbymyman's Avatar
The shifting itself is fine, it's just whether or not it actually wants to shift 😂
Old 07-01-2015, 08:18 PM   #18
Robbymyman's Avatar
A day after I fix that fuel leak..... Click image for larger version
Name:	ImageUploadedByMustang Evolution1435803492.643933.jpg
Walk outside my apartment to this...
Old 07-01-2015, 08:41 PM   #19
Steve96's Avatar
That is awful! Hit and run??!!
1996 GT
Old 07-01-2015, 08:43 PM   #20
Robbymyman's Avatar
Yeah man, this morning I was walking to my car and nearly dropped my keys when I looked up and saw the damage, so pissed.
Old 07-01-2015, 09:12 PM   #21
dwbrand's Avatar
Not cool... What's wrong with people these days?
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 07-02-2015, 01:21 PM   #22
WJL
Wow that sucks
Service Engine Soon -- What do these codes mean? Mustang803 1996-2004 Mustang GT 1 03-29-2012 09:42 AM
How to fix this codes? 6opka Pre-2005 V6 Mustang 11 03-24-2009 09:46 PM
Any idea what these codes pertain to? Zim Pre-2005 V6 Mustang 13 05-26-2005 03:47 PM
Aero Turbine Mufflers! Anyone know anything about these? BlueThunder Pre-2005 V6 Mustang 0 09-12-2004 05:23 PM
What is the difference between these paint codes..... domin8stang Mustang Audio & Video 3 11-02-2003 02:23 PM
11:39 PM
