Anybody know where to get 26 spline input shaft - Mustang Evolution
Old 06-28-2015, 11:12 AM   #1
Speed_Mister's Avatar
Region: Arkansas
I can't find anybody who makes a 26 input shaft for the tr-3650. Any have one I can buy or know somewhere that has them any local shops or anything that might have them on shelf? Help a mustang buddy out and let me get my car back on the strip.
2004 Mustang GT 5 Speed Full Bolt On 370rwhp 440rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 06-28-2015, 11:14 AM   #2
Jon3.7's Avatar
TR3650 Transmission Parts and Rebuild Kits
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 06-28-2015, 11:19 AM   #3
Region: Arkansas
Already called him he's been telling me for half a year he will have them in in a month but never does.
Full Bolt Ons
370rwhp 470rwtq
Old 06-28-2015, 12:18 PM   #4
jeno's Avatar
http://www.pro-forceperformance.com/tr3650_parts.htm
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 06-28-2015, 12:20 PM   #5
jeno's Avatar
http://www.tremec.com/menu.php?m=106
Old 06-28-2015, 12:21 PM   #6
Jon3.7's Avatar
lol
Call local transmission shops
Old 06-29-2015, 08:01 AM   #7
Call Zak.
www.the3650source.com
Old 06-29-2015, 01:27 PM   #8
Labrat's Avatar
These guys have everything your gonna need.....be it 5 or 6 speed.
D&D Performance
Labrat is offline   Reply With Quote
Old 06-30-2015, 11:27 AM   #9
Region: Arkansas
Non of those places had one called them all and they all said they didn't have one.
---------- Post added at 12:27 PM ---------- Previous post was at 12:27 PM ----------
None*
Full Bolt Ons
370rwhp 470rwtq
Old 06-30-2015, 12:28 PM   #10
Labrat's Avatar
None*
Then I would suggest doing the ol Google search and start from there.
Old 06-30-2015, 01:03 PM   #11
Zak didn't have one? Hmmm it might be only available as a gearset and they can't get it individually then...
Just FYI, the stock 10 spline one is good for around 500ft lbs at the flywheel. I mean you are making probably 425-450 to flywheel most likely so you're safe there with the stock internals. No real reason to spend the money on it or a 26 spline clutch if you don't need it. Especially if you still have stock internals which are going to limit how much you can make.
Old 06-30-2015, 02:02 PM   #12
Region: Arkansas
I've been googling and calling nobody seems to have it. I asked cal if he sells them individually and he said he did with the seals and bearings. Nobody seems to have it or make it. I was hoping a local little store near one of y'all might have some on shelf. I guess I could try quarter mile mustang.
Full Bolt Ons
370rwhp 470rwtq
Old 06-30-2015, 07:54 PM   #13
Well how many miles are on your 3650? Maybe get a full stock gearset rebuild with bronze pads, the gorilla fork and TSB synchro? Those are good for 600+ and not very hard on the budget as far as transmissions go.
Old 06-30-2015, 09:03 PM   #14
Region: Arkansas
I've got 100,000 miles on it now. And what's the max power level for stock forks and synchro's?
Full Bolt Ons
370rwhp 470rwtq
Old 06-30-2015, 09:49 PM   #15
Stock forks and synchros are really beefy but if its an original trans then it won't have the TSB fork and synchro. If it shifts great fine... but at that mileage I would not be putting a 26 spline shaft in it and calling it good. That's getting near rebuild time.
Honestly if its working well just roll with it. No need to fix what isn't broken and it'll hold as much as your motor will make right now. The input shaft is the weak link and like I said that's good for about 500.
Old 06-30-2015, 09:58 PM   #16
100,000 miles? Just get a full rebuild.
Old 06-30-2015, 10:36 PM   #17
Region: Arkansas
Yeah everybody told me to just get the input shaft. Somebody said I'd be safe with slicks since they would absorb shock from launch more.
Full Bolt Ons
370rwhp 470rwtq
Old 07-01-2015, 06:13 AM   #18
Well yeah that is true but with the 3650... that's rebuild time for an original trans that needs the TSBs done to it. You've got multiple options from a T45 to another 3650 to a T-56 variant to an A5 to an auto.
I know you take your car to the strip so if you are concerned about times you'll drop some off your ET with a good auto setup.
Old 07-18-2015, 01:04 PM   #19
Region: Arkansas
So I got a 10 spline and sent it in to liberty gear to see if they can respline it to 26 spline then going with stage 3 spec clutch.
Full Bolt Ons
370rwhp 470rwtq
Old 07-18-2015, 03:08 PM   #20
Be careful with the "re spline". If they cut the 10 spline section off and weld on a 26... eh... you don't want that but it'll work till about 600ft lbs give or take.
As far as a "stage 3" clutch... For your power level which is about what mine is going to be when I finally get this biotch running, an Exedy 400 will do fine for 500ft lbs at the crank. If you need more than that I'd jump to the McCleod RST.
Old 07-18-2015, 04:29 PM   #21
Region: Arkansas
I heard out of 4 companies one makes the really cheap ones and they break easily but they wouldn't realize which company. But this respline should do me fine. And the clutch was recommended by a tranny builder locally who does the fastest mustang in the state so I trust him.
Full Bolt Ons
370rwhp 470rwtq
Balancing drive shaft or replacing drive shaft Iryan7 Pre-2005 V6 Mustang 6 03-22-2015 11:57 AM
input shaft seal/bearing satin06silver 2005-2010 V6 Mustang 2 07-27-2014 04:44 PM
installing clutch disc onto input shaft -is it supposed to touch guide? (pics inside) paradigm 1996-2004 Mustang GT 0 06-30-2013 05:49 PM
INPUT SHAFT!!! redcobravert 1996-2004 Mustang GT 12 08-23-2009 01:59 PM
Have You Broken Your TREMEC Input Shaft? jwyche 1979-1995 Mustang GT 0 11-09-2008 10:52 AM
11:25 AM
