96 mustang gt 4.6 died - Mustang Evolution
Old 06-29-2015, 06:37 PM   #1
Region: Nevada
Hello everyone,
I need some serious help immediately please. I have a 96 Mustang GT 4.6, and it stalled on the freeway while driving 70 mph, and almost got hit by a semi. I had this happen last week, and took it to a mechanic, but think I got ripped off. I paid them $556. It cranks over, but won't start, and when you put the key in the first position, there are no dashboard lights like the brake light, air bag or check engine light. The mechanic had my car or 3 days until they finally replaced the ignition switch, relay module, and key lock. They said it was good to go, but it died in traffic today as stated above. I replaced the battery thinking that was the problem, but I'm driving across country in a few days, and need to get this fixed right away. The fuel pump was replaced a few years ago so don't think that could be the problem. I can't seem to find anyone who knows how to fix this problem. If anyone has had this happen to them please contact me please. I'm desperate, and don't want to break down out in the middle of nowhere. Send reply to iowadude41@yahoo.com
iowadude41 is offline   Reply With Quote
Old 06-29-2015, 10:01 PM   #2
Go to an auto parts store and have them scan your car for any trouble codes. Even though your Check Engine Light is not on, there still may be a pending code.
Without any direction to look, this type of problem can be very difficult to diagnose.
Old 06-30-2015, 12:22 AM   #3
Steve96's Avatar
Yeah get the codes checked. So it cranks but wont start? Not at all? Have you checked the alternator or have had it tested yet? I assume the shop would have done this? Im not sure just a stab in the dark.
1996 GT
Old 06-30-2015, 12:23 AM   #4
Steve96's Avatar
I guess it wouldnt crank if it was the alternator forget i said that. Or if its intermittent, with its issues ?
1996 GT
Old 06-30-2015, 12:24 AM   #5
Steve96's Avatar
Like an intermittent issue with the alt is what i was trying to say. Im going to stop typing since i cant get my thoughts out correctly right now, lol.
1996 GT
Old 06-30-2015, 01:28 AM   #6
Lol.
It's the heat for me... Any remaining brain cells that I had are now toast!
This is assuming that your mechanic didn't already check these things. But yeah, check the charging system while you are getting the car scanned for codes, OP.
A weak alternator/battery can cause all sorts strange things.
Old 06-30-2015, 01:30 AM   #7
Steve96's Avatar
Its the too much work for me haha
1996 GT
Old 06-30-2015, 08:06 AM   #8
fenixignition's Avatar
possible pats issue, but i think that would cause it to start up and then stop, rather than not start at all.
2002 GT 5sp. 16x,xxx miles
Old 06-30-2015, 08:14 AM   #9
infamous281's Avatar
The alt. Can cause more than just battery issues , it can cause your camshaft position sensor to act up , and your crankshaft sensor..
This will lead to no start , car dieing out , and hard to start.
It's free to have it checked out at any ford dealer or auto parts store.
Sent from my SM-N910T using Mustang Evolution mobile app
Old 06-30-2015, 08:20 AM   #10
Lorraine's driver
ab_mach1's Avatar
^yup
And try to get it fixed asap because bad alternators can kill battery's pretty quick. You want a well charged battery when you go to replace your alternator.
Instagram: @ab_mach1
Old 06-30-2015, 05:07 PM   #11
would the car turn over but not start? u stated no lights on dash panel at first detent of key on, headlights working then? if u had everything except dash warning lights working u have a ignition switch out of adjustment...if battery was dead then most likely alternator ooc.if car isn't running now any good tect can fix it....as far as the free check out at a ford dealer,forget that, not happening..if intermitted good luck,just dont let someone shotgun it by guessing and throwing parts at it..sounds like what last guy did, as well as overcharing you big time
ALLYDRIVER1 is offline   Reply With Quote
My 92 mustang died please help please wont start HybridTruth93 1979-1995 Mustang GT 2 05-04-2014 03:07 PM
Yet Another "Mustang Suddenly Died" Question ElSaborAsiatico 1996-2004 Mustang GT 27 12-23-2013 12:43 PM
Mustang died Mike93coupe General Mustang Discussion 0 12-20-2013 07:44 AM
My VW died for the last time...... or why i bought a 09 Mustang GT dagamore New Member Introductions & Greetings 15 10-24-2008 05:23 PM
Anyone know anyone that has died from Mesothlioma?(asbestos cancer) Brent The Bar 5 04-08-2004 10:37 AM
09:46 AM
